  New Posts New Posts RSS Feed - Ecler Amps working at 16 Ohm loads?
needle fx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote needle fx Quote  Post ReplyReply Direct Link To This Post Topic: Ecler Amps working at 16 Ohm loads?
    Posted: 11 March 2012 at 7:07pm
Hi everyone.
I have being looking around i even try emailing the people at ecler with no success :(
Can anyone tell me if the ecler amplifiers from the series APA and DPA can be used at 16 ohms?
Thanks for any info.
audiomik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2012 at 7:17pm
Should be absolutely no reason why they wont!
All other Amplifiers do, unless designed and built specifically for 70 or 100 Volt line outputs.
Although setting the output impedance for Valve Amplifiers is quite important, but even they then drive 16 ohm loads happily.......
Mik
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2012 at 7:33pm
Absolutely no problem with 16 ohm loads
we are Dealers in Romania for ECLER
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote needle fx Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2012 at 11:38pm
Thank you both!! Big help!! Smile
This page was generated in 0.344 seconds.
