Ecler PAM switchmode amps any good |
Post Reply | Page 123 4> |
C-Audiofreak
Registered User Joined: 12 June 2014 Location: Norfolk uk Status: Offline Points: 467 |
Posted: 28 April 2016 at 6:48pm |
Hi all has anybody got any experience with the Ecler pam switch mode power amps how do they compare to other old school top end amps C-Audio Yorkville void mk1 inf series HH etc?
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4949 |
AFAIK the PAM series are linear
North Staffordshire |
jbl_man
Yup,conventional power supply as far as i'm aware. Well all the ones i have seen are.
Good solid old amps,but getting quite old now. |
C-Audiofreak
They still seem to command a reasonable price second hand would they have been in the same league as the old c-Audio SR range in terms of build quality sound quality and balls?
C-Audiofreak
The ecler pam 560E that I have just bought spares or repair states on the front switching power MOSFET amplifier is this different to switch mode power supply?
jbl_man
Best way,open it up and post a photo?
kedwardsleisure
The 'switching mosfet' is a misnomer and a dubious marketing ploy. It simply means that they used mosfets in the output stage that were primarily designed for switching use rather than linear use. The amp has a standard transformer power supply and a linear output stage.
They're a nice quality amp though, at least as good as an SR, if you can get a clean one. (the ecler and the SR both suffer from corroded steel and flaking powder coating!!). Common faults to name two are failure of plated-through holes and rusting chassis causing the powder-coating to jam the fans. |
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
+1 Yep, their chassis are terrible quality. The front panel/grill is somehow better coated but the rest is very poor. Edited by M4trix - 29 April 2016 at 10:18pm |
C-Audiofreak
If racked and kept indoors in dry conditions should be ok it's in good condition the one I have got
M4trix
I actually wanted to suggest a flight case for such amps, especially for outdoors and rough handling. Btw, take a look here. It's Leco's website (Romanian language) and shows your amp inside. Not much to see. A simple ol' skool amp. http://www.forum.poweraudio.ro/viewtopic.php?t=6623 Edit: SMD parts are on the bottom side of the PCB. Edited by M4trix - 29 April 2016 at 10:46pm |
C-Audiofreak
M4trix on the source leg of the fets there is a small what almost looks like a choke of some sort when i replace the fets i have do i need to place those on the source legs of the new fets? |
M4trix
Yep, those are ferrite beads and they prevent possible oscillations. Place it back on the gate. The explanation is on the picture.
