Eminence Recone question........ |
jaya000
Joined: 24 August 2008 Location: India Status: Offline Points: 44 |
Topic: Eminence Recone question........Posted: 29 April 2009 at 5:55am |
I think u can covert 4 ohm model to 8 ohm, but not the reverse.
It is only possible if the magnet gap between top plate & T yoke is same.
For 8 ohms the wire thickness is less but for 4 ohms it is more.
Hence the resultant voice coil o.d. is little different.
So many times manufacturers use different top plate i.d.
hopalong
Joined: 28 November 2008 Location: Norfolk Status: Offline Points: 181 |
Posted: 23 April 2009 at 12:06pm |
Top man. Thanks Markie.
markie
Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 2479 |
Posted: 23 April 2009 at 11:18am |
Magnets and chassis are identical so if you use an 8 ohm re-cone you'll have an 8 ohm driver.
hopalong
Posted: 20 April 2009 at 9:17pm |
Thanks mate, appreciated.
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 3382 |
Posted: 20 April 2009 at 9:14pm |
i think it's just the coil determines the impedence.. so yeah... it sounds to me like you're right... i'd wait for another opinion though, to be sure..
hopalong
Posted: 20 April 2009 at 9:07pm |
Anyone have any idea ?
Or am I just being dense ?
hopalong
Posted: 20 April 2009 at 10:26am |
I'm biting the bullet and I'm going to have a go at reconing a couple of Eminence Kappa 15s.
One is a Kappa 15C ~ 4 ohms, the other a Kappa 15A ~ 8 ohms.
Can I use the same recone kit, for a 15A, for both and end up with two 15As ?
That's the goal.
Cheers, Rob.
Tweet
