ES18-BPH |
Post Reply | Page <1 2930313233 35> |
Author | ||||
Father-Francis
Old Croc Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
I used Burl foam / egg crate foam (soft foam type)
it made them sound better ,
m0gsi
Registered User Joined: 09 February 2015 Status: Offline Points: 99 |
Anyone got any experience with the RCF LF18G401 in this cab? They look like a good value driver.
corell
Young Croc Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
It will perform very good. Its an excellent choice for BPHs.
screeldnb
Registered User Joined: 18 June 2013 Status: Offline Points: 22 |
How come the recommended driver for this has a response 35hz-200hz and yet the box is recommended for use up to 250hz?
SpeakerFreaker0181
Registered User Joined: 22 April 2015 Status: Offline Points: 13 |
I have built 4 of these cabs which I just finished recently. I'm currently building 2 Hog scoops.
I also have built 3 bassreflex cabs in the last 2 years. One TL505 with a EVM18B and 2 http://www.forum.poweraudio.ro/viewtopic.php?f=92&t=9645 - Subwoofer 18inch-supercompact with 2 Gauss woofers. Planning on building 2 PAS3MA2 after the Hogs are finished. Now I have the very common question: which drivers do I put in the es18-bph. I've already read about a lot of drivers on the forum but now I found 4x Behringer Eurolive 18SW400D8 seconhand available at a two hour drive distance. The seller priced them at 300 Euros and the highest bid is currently 175. I think I can get them for a bit less than 300 if I try. some specs I found: 400 Watt cont. 1600 Watt peak 100 dB half space 1 W @ 1 m 40 - 300 Hz (-10 dB), 8 Ohm Assuming these are in working order, would these drivers be a good option? They seem rather cheap but I'm worried whether the quality will be good enough and whether they will go well together with the es18-bph. |
cravings
Thanks(1)
i haven't looked at their proper specifications but i doubt they'll be any use to you really. you'd be much better off getting second hand quality / recommended drivers.
SpeakerFreaker0181
Thanks for your reply.
I also haven't been able to find proper specs. I did find some site saying that the Behringer B1800X Pro is loaded with this driver. https://www.music-group.com/Categories/Behringer/Loudspeaker-Systems/Portable-Speakers/B1800X-PRO/p/P0288 It all looks good, but I'm not so sure where on the quality spectrum Behringer is compared to brands like PD, Fane, EV etc... I did read Behringer focuses on making budget products with a high quality. I'll try to find some of the recommended drivers in the coming months, I'm not in a hurry as long as I'm not finished with building the hogs and pas3ma2's |
Mark James
Thanks(1)
the mk1 p audio challenger 650el is available new from blue aran atm, altho once they are gone its unlikely anymore will come along theres an option meant to be rather good in that cab
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
Anyone know the delay time for the es18 in Milli seconds? Above super scoops..
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 663 |
thats a good question...this forum lack to share this kind of information...if i don't remember wrongly mine is around 28/27ms but i cant check right now sorry
cravings
it's not that people won't share that information.. it's just that there isn't a definitive answer. different drivers, different filter points and slopes and all sorts of stuff affects this.
and 27ms is like.. a 9 meter delay or something.. |
_Natty_
?ok my mind forget the right number on the delay settings forget me :D i guess that delay was just about horn path, such hard thing to cover in all is aspect so :)
