EV P3000 |
Post Reply | Page 123 5> |
levyte357-
Posted: 01 February 2017 at 1:29pm |
Old heavy, thirsty amp but very good, even if it gets a bit hot..
Been offered a few, wonder if there's a mod, for it to run a bit cooler !? |
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
dont switch it on
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4538 |
Haha. Does the heat cause any problems? If no then i wouldnt worry.
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
install in cold room
North Staffordshire |
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1780 |
Time to dig that thread out on air conditioned amp racks ;-)
Father-Francis
Old Croc Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
http://www.overclockers.co.uk/water-cooling
here you go
BASSHORSE
Young Croc Joined: 19 September 2007 Location: wolverhampton Status: Offline Points: 1145 |
as ken said,.ive had a few now for over 10years,,no service,,still goin strong,.although i have hoovered the dust out one or twice,.im stickin with them anyway,,sound lush from 20hz to 20khz,.i have got the dynacords l2400 aswell,,ther like brand new,,& seems to run a little cooler than the older ones,.i like um
levyte357-
Few years ago, repair dude said these will sound great, right up until they cook themselves too death!! |
valve head777
Just keep them clean i guess.
luton_soundman
Bring your lunch with you to the gig, have a fry up on it
kedwardsleisure
also helps if the bias is set right. The pots on these drift and can lay on the bias pretty thickly. A quick test is to let one idle on the bench for a few minutes. It should cycle the fans on and off between 'stop' and speed 1.
The other option is to plug it into a watt meter and check the idle power consumption is as per spec sheet. |
Marvin
Young Croc Joined: 28 December 2007 Location: London UK Status: Offline Points: 1029 |
Great amplifiers. I have up for grabs
