EV P3000 |
Post Reply | Page <1 2345> |
nev23
Registered User Joined: 08 September 2008 Location: Taunton, UK Status: Offline Points: 99 |
Don't bridge it into 4 Ohms. And use a limiter. But in a way, it is useful: it is telling you something is wrong.
Vaso_Bobinata
Registered User Joined: 21 May 2017 Location: Sofia BUL Status: Offline Points: 37 |
Many thanks. Feedback appriciated 😊
Will it be ok in 2 and 2.7 Ohm in stereo. |
nev23
There are several models in the Macrotech range. I haven't seen all of them. Some may be good into 2 Ohm per channel or 4 ohm bridge. Some may not have the accurate protection, that sounds rough.
If you have a model number, I will look it up. |
Safetyman
Young Croc Joined: 08 February 2009 Location: Brighton, East Sussex Status: Offline Points: 555 |
I have found, over the years, that increasing the air-flow to the amp rack as a whole, on the 'suck-it-in side keeps everything much cooler. Personally, I use an 18 inch floor fan to both cool me and the amp rack, which works for me.
I remember one very hot day ( high 30's in the shade ) , where a friend turned-up in full one piece leathers on his motorbike. He was ok, for about 5 mins, then had to feel -off the suit. He assured me that , despite the heat, once back on his 'bike, the air-flow would cool him down nicely very quickly. :D |
Protect your hearing, and feel the music.
MU South East Roving Safety Rep. |
nev23
The wind chill effect lessens with difference in temperature from the cooled object. For humans,wind chill become hairdryer in the face when the temperature in the shade is above blood temperature.
I'm surprised about the leathers; they are prety much completely windproof. |
Safetyman
I was assuming that the rack temperature inside was hotter than the ambient air being drawn in......
tonysparks69
Registered User Joined: 27 October 2017 Location: Doncaster Status: Offline Points: 16 |
E.V. P3000's get hot because the biasing tends to go out on these amps. Its a well known fault and every time I get one in for service I check and reset the bias. Its only a 5 minute job once all the lids have been removed.
I would find a reputable service engineer to do it for you and clean the heatsinks of dust and all should be fine. Tony. |
nickyburnell
And the fact people think they are hot because the fans actually get the hot air out, not spin it around inside
Edited by nickyburnell - 29 October 2017 at 3:32pm |
ceharden
I've said it before but these amps really need a gap between them. The pre-amp section which is directly under the top lid has no airflow to it.
nickyburnell
Agreed although I think the extraction is quite good. Mines a Dynacord version, using 4r stereo as a normal amp not a welder running scoops helps it stay cool as well
Edited by nickyburnell - 29 October 2017 at 4:35pm |
JBK
Registered User Joined: 03 March 2016 Location: Besançon Status: Offline Points: 262 |
You know there's actually a french sound system calld "Welders HiFi", and guess what... they run scoops |
EmPro
Young Croc Joined: 26 June 2020 Status: Offline Points: 766 |
Honestly...i don't know what tipe of brain disorders you need to have to ever thinking to compare EV P3000 with MacroTech's,by the time when not even a rusty bolt will remain from a P3000 the MacroTech's will be still there playing music,most of people talk trash because not even after 35 years since the Macro's are on the audio market they don't know for what these amps have been created and where and how to use them for the best sound reproduction,also the meintenance is out of discution,i've seen working MacroTech's with tottaly blocked cooling fans in them!! They just reduced the sound to a safe level and keep going hot as hell,but i never seen a P3000 not blowing up and fixed at least 3 times! So please....get to reality,when you play +1kw of power and up i'm quite sure nobody give's a about smoothneses of the sound,we're not listening 140db in bedrooms so.....
Edited by EmPro - 11 January 2024 at 11:59pm |
EmPro Audio
