  New Posts New Posts RSS Feed - Extended CB-18 Cyclops
 Post Reply Post Reply Page  <1234 17>
streetsounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2010 at 11:03pm
Originally posted by Crazy Dane Crazy Dane wrote:
Which of the 3 versions performs the best then?
And is it possible to get plans for them all?
Wait. Ill figure out how to post the plans..
Bass matters...
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2010 at 1:01am
Getting coated with fiber matting and polyurethane
Some more sanding and do the final coating including the aluminum corners.
Edited by streetsounds - 12 November 2010 at 1:05am
Bass matters...
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2010 at 7:41am
Originally posted by streetsounds streetsounds wrote:
Good job, mate!
What are those cabs behind? SB-18 or half MTL-1X?
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2010 at 7:42am
Looks good. I did spot you fibreglassed over the nut-holes for the driver attachment didn't you.
At least you know it will last forever now you've fibreglassed id. Just wondering if you'll be putting a grill on?
Best regards,
Teun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2010 at 9:53am
Yep fiberglass over the bolt holes but just poke it and there will be hole again. Ill put screen on it but just by the square opening, and then put also a detachable board (via twist lock) with 4 wheels on it.
Bass matters...
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2010 at 9:57am
@ Ibex: They are modified T-18 they called it here Sub-scoop, deeper but narrower than T-18
Bass matters...
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2010 at 12:00pm
Finally completed 2 of the 6 Cyclops Im building, these two will be on their first job tomorrow.
Bass matters...
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2010 at 12:15pm
love the grill and wheel board arrangement! Clap
what made you decide to fibreglass over them, was it necessary?
F.T.S.S.
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2010 at 12:23pm
Thanks..To make it more tougher against bumps and scratches, its common here in my place that diy speaker bins are coated with fiber glass.
Bass matters...
Speaker Sol View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2010 at 12:58pm
 Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2010 at 1:47pm
I could not able to put the volume to normal level, neighbors ang complaining about the bass
Edited by streetsounds - 01 December 2010 at 1:50pm
Bass matters...
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2010 at 2:01pm
Clap mmmmmm , looks serious, compact rig, very tough and pro.
What is sound "feeling" in front of 3 CBe-18 stack?
Beer
Just do it! ..or do not.. ;)
