  New Posts New Posts RSS Feed - Extended CB-18 Cyclops
 Post Reply Post Reply Page  <12345 17>
streetsounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2010 at 2:08pm
I could not able to test it fully, neighbors are screamin', but even with a very small volume adjusment you feel the bass. With just 2 cyclops the bass was intense., I just noticed the driver cone moves a lot, Maybe i need to high pass it to around 40 to 45hz
Bass matters...
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2010 at 3:46pm
35Hz L/R or Butterworth 24db/oct will provide enough mechanical protection even on highest power.
If you feel that you really passing safe margins you may set it up to 40Hz.. above that there is no more point of rising HPF to protect driver , only reason for further rising may be to "preserve" some amplifier power headroom.
Also to note it is not good to completely minimize or "kill" cone movement as it is very important for voice coil cooling / air flow around VC gap and through magnet structure.
By totally reduced cone movement it is much easier to fast increase power compression and turn speaker unit into audio driven heater and under that conditions it is easy to burn voice coil as you cant hear any distortion and its sound level seems lover (and it most likely really is.. due to heating/power compression)  than you used to use before.
Some companies especially for bass cabinets intentionally recommend lower HPF filtering points that theory suggests as safe to improve that cooling effect by intentionally allowed bit of extra-excursion  (but for that they select or design drivers so they can be confident that mechanical damage point is still far from voice coil "reach" and that extra bit of excursion do not make unwanted audible noises)
BTW .. only on very close listening , most of bass drivers on back side may produce slight air "chufing" tones by the magnet pole-hole. This may be audible only on close listening a.k.a. "head in speaker" and it is not audible at all and will not affect sound when you move even 50-60cm away.
..just in case to not confuse this with real "cone farting" Wink
Best wishes, Stipe
Edited by staiper - 01 December 2010 at 8:57pm
Just do it! ..or do not.. ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 2:47am
Yup I did it last night Stipe killed freqs below 35hz and low pass it to 140hz. I rigged it up with the live band and with just 2 cylops a side the bass was amazingly intense, finally managed to tune it properly. Its a very efficient box I would say, small amount of power exerts lots of bass. I could say that this is a "power amp friendly bass bin", you dont need to push the amp that hard to meet the bass you want., I think this CBe-18 will outrun many sub bin design..but thats just me. Thanks for the design and for the tips Stipe.
Bass matters...
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 3:54pm
r u guys putting out the extened palns???
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2010 at 11:01pm
Here's the plan link, took a while to figure out how to share it
http://www.4shared.com/document/IEzkx4z_/Cyclops_CBe-18_standard_extend.html
Edited by streetsounds - 06 December 2010 at 7:11am
Bass matters...
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 1:51am
the link is open small cant read
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 5:50am
You have to download the file via the download now button ...
Louder than loud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louder than loud Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 5:51am
love the look of these :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 7:13am
Yes you have to download it and you must have an acrobat reader
Bass matters...
Danny A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danny A Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 8:22pm
Hey Streetsounds, your build looks really good, interesting finish, Ive neverseen it before. Wheel boards looking good too Clap
What tops are you using? DIY?
Ibex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibex Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2010 at 9:47pm
+1
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2010 at 8:23am
Yup some sort of a DIY midtop. Thats a double 12" mid with hi comp driver at the center similar to mT 122 but shorter and deeper. Drivers installed are 2 PAudio C12 500MB for the mids and PADE99 for the hi.
Bass matters...
This page was generated in 3.063 seconds.
