  New Posts New Posts RSS Feed - fane 18-1500
fane 18-1500
highlyunlikely View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote highlyunlikely Quote  Post ReplyReply Direct Link To This Post Topic: fane 18-1500
    Posted: 20 July 2009 at 12:49am
have had a quick look with the search but nothing conclusive..has anyone built g subs with the fane 18-1500?will be driven by ffa amlifier 8000 upwards.
does this sound a good idea or am i just going to be waisting power?
ps nice forum quite an entertaining place!!!Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote highlyunlikely Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2009 at 4:44pm
anyone??
SteveAATW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveAATW Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2009 at 4:55pm
It's a relatively new driver that requires inordinate amounts of power to drive it, I've never seen anyone mention trying it in a reflex yet. It would probably work in the GSub but you'd have to look at how much output increase you get in some simulation software to decide whether the extra cost and weight is worth it over a normal 18XB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote highlyunlikely Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2009 at 5:05pm
thankyou thats what we were thinking...someone else said to have a look at 18 sound lw 1400 instead,the other option would be the fane 1000.which would people have preference over?
thanx
djshaney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djshaney Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 6:04pm
hey mate, did you try the higher power fanes in the end?
mine are 18xb loaded and sound immense, and was (like you) just wondering if its worth using the 1000/1500's.
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 7:02pm
Have only heard Fane 1500s in Mini scoops.
But Matrix STR3000 will drive 1x per channel no problem, in reality these drivers will only take approx 1kw before losing it..
Edited by levyte357 - 23 August 2009 at 7:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote djshaney Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 7:17pm
1kw... is there any point in it over an 18xb then, considering it has a lower
sensitivity?
apart from the higher bl maybe? 25 plays 32...
Edited by djshaney - 23 August 2009 at 7:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 23 August 2009 at 7:57pm
sensitivity?
The 18-1500 has higher BL, and larger Xmax.
This allows the 1500 to play lower notes at higher volume, well after the 18XB has lost its lunch. It is very close in perfromance to Turbomax 1200.
The 18XB is a nice little speaker, but Fane 1500 is on the top shelf along with 1850, V18-1000, Turbomax 1200/1500.
Edited by levyte357 - 23 August 2009 at 7:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote highlyunlikely Quote  Post ReplyReply Direct Link To This Post Posted: 24 August 2009 at 6:26pm
in the end went down the 18 sound lw 1400 route,as a better option for me.
zippi
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2013 at 9:03pm
That's better for relfex!
Well now the driver is obsolete
Performs really well in invader it seems, I've got 12 of these drivers, last 12 coming out of the fane factory for me:-) -Starting out in smaller bph, but invaders look good if 3 pcs can do 30 hz:-)
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2014 at 10:53am
I must say I'm very impressed with this drivers performance in bph, it certainly DOES NOT demand a lot of power!
For some reason it plays a lot louder than the 18b600 that the bph was made for even at the same power.
I never managed to play these babies full power, this Wednesday I had 16 out, driven only by 2 digam7000, same as I used for my 18b600. We couldn't even drive these small amps to maximum!
Everything was jumping off the FOH table, the mixer had to be taped to the table.
Ideally I would play them with my lab13000 just to get the rms power for the drivers, driving them at program power must be insane, so far I've only been around 1/4 to ½ power!
I hope to get them out this summer.
Only worry is what happens if I burn them, will a serious company like fane still supply kits?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 9:21am
You're playing them in BPH cabs, not sub, and playing 16x of them ?
