  New Posts New Posts RSS Feed - Fane 400W 18"
Fane 400W 18"
Goodvibetribe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goodvibetribe Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2012 at 1:23am
Originally posted by scott_fury scott_fury wrote:
I may have got the Vas wrong for the Fane's. Looking at the Thiele-Small database I reckon it's 209 litres not 366.
Build a super scooper, ensuring you have bib handy, for drooling at the effortless notes rolling out, when you load it with 18B400.
EDIT:18B400 has parms similar to Bline 18-800, and that is a stonka' in SS18.
Lev, Would you say its worth me just building superscoops then to replace these, rather than hunting for the plans to build more: http://forum.speakerplans.com/scoop-id-needed-please_topic74382.html
If thats the case then im also after another pair of 18B400 im getting the impression they seem to be quite sought after still, I Certainly dont have complaints with mine.
(sorry to crash your thread with this question Scott)
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2012 at 1:36am
Would suggest you search around for used Supers, before building.
They work splendidly with many Fane drivers.
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2012 at 6:45pm
the old fane studio 18 is probably one of the best drivers that have ever graced the scoopists.
F.T.S.S.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2012 at 7:27pm
Yep, parameters typify quintessential scoop driver.
If only Fane could have given it, Xmax=12mm, BL=32, 800W Power handling, without changing anything else..
Cry
onefootskenk77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote onefootskenk77 Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2012 at 12:21am
Have 300 watt old fane in scoop 😍😜
EMPIRE SOUND
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2012 at 11:04am
Best SOUNDING scoop driver bar none
Best scoop design for this is the Fane 15'' scoop scaled up by multiplying all the measurements by 1.2. Keep the width down to 24'' 610mm wide though
........how does he know this members might ask.......ANSWER:    I used to own 16 of them : )
scott_fury View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott_fury Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2012 at 6:29pm
That's a pretty solid endorsement!
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2012 at 10:28pm
I heard 3 in scoops on the end of a JTS pre & JTS 6k amp combo
Surprised with how good it sounded!
soundchippy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundchippy Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2012 at 10:14pm
in the beginning we had a superscoop with one of those fane 400's. did the business for years and sounded good doing it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott_fury Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 5:54pm
That's the internal width, not including the thickness of the sides? The 15" Fane scoop has an internal width of 565mm, which x 1.2 gives 678mm. It's this that should be reduced to 610mm?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2012 at 7:40am
Cry
not far off the SX is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2012 at 7:41am
Yes.........WARNING! ignore the mm given on the drawing......it's way off LOL use inches then convert yourself
This page was generated in 0.092 seconds.
