  New Posts New Posts RSS Feed - Fane Driver Help
Fane Driver Help
RiddimKid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RiddimKid Quote  Post ReplyReply Direct Link To This Post Topic: Fane Driver Help
    Posted: 14 May 2017 at 11:48pm
Hey peeps.
A mate of mine removed a driver from a box last week. After screwing out all of the screws the driver was stuck so he knocked the box to get the driver unstuck. The driver fell out and this happened
Is there a easy fix for this? The connector was on the box wire, it has completely sheared off.
Thanks
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 1:28am
you can get replacement terminals, in fact I probably have one on a scrap driver here that had a shifted magnet.
100% Earth Moving Bass
Post Options Post Options   Thanks (0) Thanks(0)   Quote RiddimKid Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 1:54am
Thanks for the reply mate.
Had a look online for a replacement terminal but had no luck so far. That would be perfect! Thumbs Up
valve head777 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 8:38pm
Wembley loudspeakers might help.
