  New Posts New Posts RSS Feed - FFA amp power question
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Topic: FFA amp power question
    Posted: 10 March 2017 at 8:06pm
An FFA 6004 amp is rated 6000w, yet only has a 20a Powercon, so could only get 4800watts?
How are u supposed to get its max usage out?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2017 at 8:20pm
Read a little on reservoir capacitors (capacitors as reservoirs) for starters. Amps are a big topic though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2017 at 8:59pm
Cheers, I figured there was a way, was just interested as it confused me a bit...
its definitely a big topic though.
big up fore the reply
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2017 at 11:45pm
AC watts does not equal Audio watts, audio is much more dynamic than the sine wave that comes out of the wall so part of what an amplifier does is store some of that energy to be used to reproduce peaks. And regardless what a spec sheet may suggest those amplifiers will not deliver those rated output figures indefinitely, look further into the specs to see what method was used and what the test signal was, chances are you will find it was a noise signal with a defined crest factor and was time limited.
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2017 at 12:51am
spec sheet says it's 1kHz sinewave. probably for 10ms.
MPASOUND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MPASOUND Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2017 at 4:23pm
Actually FFA are one of the few that can deliver sustained power and pretty much meet the manufacturers spec. Not sure about the four channels but take a look at the amp meet 3 results for the FFA 10000.
It's just bits of paper flapping about in a box..
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2017 at 10:16pm
Cheers for all the answers guys, im researching as we speak, I'll get ther.
Nice one!
