  New Posts New Posts RSS Feed - firewire crackling problem
jamie-ashton-solo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamie-ashton-solo Quote  Post ReplyReply Direct Link To This Post Topic: firewire crackling problem
    Posted: 28 January 2015 at 7:34pm
Hoping someone can help with my long running problem.
I have a mackie onyx 400f interface,into a windows 7 i7 quad with 32 gb ram. The problem I'm getting is crackling when playing back audio after a while.. Sometimes an hr. Sometimes 10 mins. I have texas instruments chipset. The only thing that stops it once started it resetting the buffer on the mackie software.. But then it happens again after a while. I've tried 3 different cables,and 2 different firewire cards to no avail.
Hope someone can help.
07756215776.
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2015 at 1:33pm
It may be caused by the incompatible chipsets as well.
Download Latencymon http://www.resplendence.com/latencymon and see what actually is causing the issue. Sometimes it is wireless network driver causing the issue. That Latencymon will give some answers what to do next.
This page was generated in 0.250 seconds.
