  New Posts New Posts RSS Feed - First build 15 inch sub
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Topic: First build 15 inch sub
    Posted: 10 May 2017 at 10:11pm
So here goes.
Never built anything like this before and the learning curve has been steep at times. Thanks a million to bee and diyxover without whose early responses I'd have probably given up. Instead I kept going and came up with my own design.
Thanks to my friend mark for use of his garage and assistance. I promise to stop boring him with stuff I've found out as soon as we have tops built and are running dsp.
First panels cut
Then I finalised internal bracing design and made that
Dry clamped the box with driver in and rolled over a bar to get centre of gravity to position handles (did this before the bracing actually)
Messed up the baffles so made a second set
Baffles done, rebates cut and ports in! Felt like I was getting somewhere!
Edited by JonB67 - 10 May 2017 at 10:22pm
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 10:19pm
Looking good so far!! 15" drivers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 10:21pm
Btw this is for a bms 15n630 in a 90 litre box.
Port detail. Cut the rear baffle so the pipes are a really snug fit, then routed the front with a trim bit then a roundover.
Probably the best shot of the detail of the design, for better or worse.
Box assembled.
Needs handles cutting in and a rebate for the speakon plate and then it's ready to test... and I need to glue the other one up. This one's coming to a gig on Saturday just for a test though!
Edited by JonB67 - 10 May 2017 at 10:23pm
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 10:22pm
good work!
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 10:29pm
Tidy!
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 10:29pm
You've made a nice job of that. Ports look really nicely done.
Speaker Sol View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 10:33pm
Very nice.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 3:59am
Lovely work!
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 9:00am
Very nice. Well done. What driver are you using?
Rish
Edited by rish - 11 May 2017 at 9:01am
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 9:03am
liking those ports and braces.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 9:09am
It's a bms 15n630 rish. It's built to the bms recommended spec of 90 litres and 43hz.
Figuring the best way to maximise bracing for minimum weight was what took me the longest. Lots of cups of tea and sketching on graph paper.
I was a little concerned it might be too close to the vent in the magnet but as no one's said it'll be a huge problem I'm guessing it's fine!
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 11:08am
Lovely driver and build. Tony Wilkes would have been proud.
Rish
