  New Posts New Posts RSS Feed - FFPA our story
FFPA our story
 Post Reply Post Reply Page  <1 3839404142 52>
empiresoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote empiresoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 1:15pm
Originally posted by spongebob spongebob wrote:
As far as i'm aware, ratchet straps are not rated for lifting
Article 126
http://www.hseni.gov.uk/l113_safe_use_of_lifting_equipment.pdf
Failed DJ and fumbling through the world of pro audio. Give me a thumb and make me feel better:
www.facebook.com/empireAVWorks
nuclearbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 9:27pm
Article 126
clearly says you should not normally....
it wasnt a normal situation
anyway i thought youd be too busy setting up more fake profiles and trolling peoples groups mr beswick, and didnt you sell your system as no one would use you due to lack of a kick sectionTongue
Edited by nuclearbass - 24 January 2016 at 9:43pm
one life - have fun!
Force fusion pro audio
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 10:11pm
Its pretty simple. If you don't know why something is or isnt right for the job you are not qualified to do the job.
Rich Please don't lift things with Ratchet Straps. There is no saftey restraint on the load once you lift the release on the handle.
Also the loading on a Ratchet strap is not rated on a downward force load. I.E if you hung 10,000kg of metal on a 10,000kg ratchet strap it would snap instantly.
Use the Method with the winch stands.
Anyway, Weldone with the Floodlight! Still one of my Favourote boxes of all time. That 12" on Vox is just bloooooody lush.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 10:34pm
it wasnt secured with the ratchet it was chained up there with 4 chains spaced out, i think the hardware were rated at 250kg each, the kit on there must have weighed less than half that, once it was up there it was safe, the straps wasn't ideal but it did the job and with only our selves there "yes a bit naughty" but it solved our problem.
we have how ever invested in some chain winches in the mean time.  This was the first time wed been asked to do a dead hang so didnt have any
Post Options Post Options   Thanks (0) Thanks(0)   Quote empiresoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 10:42pm
Article 126
sigh, last time I stick up for you lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 10:45pm
Article 126
if i needed you id be in a sorry state of affairs mate, get back to blocking people who give you solid advise on facebook
Post Options Post Options   Thanks (0) Thanks(0)   Quote empiresoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 10:48pm
Article 126
*advice lol, all the best Richard x
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 10:50pm
typo, oh well, I
i don't recall this being a spelling forum
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2016 at 10:52pm
im not sure how unsafe this is classed as but i thought id share it anyway, its in our own unit for the cinema night we did
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2016 at 10:56am
Well done on the ordering of the chain blocks.
Have you had a google on how to strop and shackle truss?
Sling These are common for going round the truss. Also can be used for the point, especially good for wooden joist's in old buildings etc. Not ideal for I-Beams.
3.25 Bow Shackle Bow shackles for connecting straps to chain blocks.
Please note all this kit should be tested to LOLLER standards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuclearbass Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2016 at 11:42am
That didn't work
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2016 at 8:47pm
i actually love how you don't give a crap! Thumbs Up
everybody has to think on their feet every now and again, using ratchets isn't ideal but better than some poly rope from the hardware shop, or two blokes stuggling up a ladder!! You have the right kit now for future use, fair play. I've done MUCH worse but we shan't speak of that haha.
Also note, shouldn't use chains on the truss either as they don't couple the load evenly on the truss chords - which could cause pinch points malforming the chord and compromising structural stability [ie: chain links could dent/slice the tubes of the truss]. Use rated slings for primary fixing, with plastic wrapped rated steel cables/shackles for secondaries [in case of fire melting said slings].
happy days! Lamp
