  New Posts New Posts RSS Feed - need plans for a good line array
arpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arpc Quote  Post ReplyReply Direct Link To This Post Topic: need plans for a good line array
    Posted: 02 September 2007 at 12:08pm
Yo guys!Please give me some good plans hot should i make a Powerful Line Array system, i have no idea how to make it and thats why i want some help.So please give some tips, plans how to make.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2007 at 12:12pm
Why do you thik some of the Line Array boxes cost as much as 15 000 $ per box?
It takes more than just a plan to do them.
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2007 at 6:03pm
Blahblahblah
soundsystemdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2007 at 7:10pm
If you're up for some tricky woodwork try Bill Fitzmaurice DR range.
ddujovic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddujovic Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 8:02am
For me the line array speakers (most of them) are not so special and no hard to build these boxes are only a  standard vented boxes. All is in the HF part of the box but you have to buy a horn adapter for a line array and thats it. And if you want you can put some Mid drivers. The minimum cabs per side is 4 and the line array can't reproduce a high spl Low's so you need a stack of bass boxes!!!
Link for horn adapter
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 8:20am
Then why not everyone make a line array boxes????
First you need to understand the technology and learn how to apply it.
Drivers has to be carefully positioned in order to achieve what it suppose to.
If drivers to not couple well than it is just a reflex box turned on its side.
Driver selection is also critical and some of the best LA boxes are not reflex one (EAW, Martin...).
Then the processing must be implied to phase and time align the drivers.
And...
some of the LA boxes can produce serious bass if its needed. As a mater of fact every LA produce more bass then HF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddujovic Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 8:48am
sory i don't see nothing special in this box exept the MID/HIGH part ansd also there are not so special!!! You have rihgt on processing but is not so dificult!!!!
link
http://www.jblproservice.com/pdf/VerTec%20Series/VT4887.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 9:10am
Yes it is not so difficult but for someone that has extended experience in box building.
Not for someone stating something like the original poster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 9:13am
Oh.. and what about the rigging equipment security and insurance part.
The rigging stuff must be certified.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddujovic Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 12:29pm
I think that rigging can be also solved by guys that make stell staff!!
dalo bi se napravit dobar array!!
Edited by ddujovic - 03 September 2007 at 1:05pm
Sibulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sibulus Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 3:58pm
You might want to try something a little bit less full on if thats the case!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2007 at 6:46pm
Da ali ovaj ti pojma nema ni o cemu :-)
