  New Posts New Posts RSS Feed - My 18" horn, Invader Bin
 Post Reply Post Reply Page  <1 3334353637 39>
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2014 at 10:36pm
Originally posted by Dub Specialist Sound Dub Specialist Sound wrote:
nuff sound fight fi de corner
Yeah I know if you read back a few years you will read that I suggested it for reggae sounds. But its not real world is it
Mykey Wattco
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2014 at 10:56pm
Originally posted by KidCreole KidCreole wrote:
That's 9 in a corner
who puts speakers in a corner? What if you haven't got a corner?
my sim is 2 ohm x 4 in corner
LMAO!
YOU just put 4 in a corner! That's what you're writing, and NO it's not 9 in a corner.
AND: 2 ohm x 4 makes ½ ohm!
9 in a corner is 10 cycles below that = 30 hz:-))))
THIS IS 9 in a corner according to the sim that I've been asking about soo many times:
Edited by tv00 - 28 December 2014 at 10:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2014 at 11:02pm
4 x 8 ohm = 2 ohm
1.41v 0.5 pi
Mykey Wattco
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2014 at 11:08pm
I guessed that one, still you put yours in a corner
& no the other sim was just ONE box in a corner, not 9!
One in corner should equal four boxes on ground in low end extension, but if yours also are corner, then the invader should be even better.
It all comes down to the same questions about the simulations that I kept asking, now we're just talking SPAM
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2014 at 11:13pm
Invader better than c4? 😂
you're getting confused and hoping too much. You havnt started building them have you😵
Mykey Wattco
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2014 at 12:21am
No, first I learn how to use hornresp!
Read before you write anymore thanks.
The sims you posted was nonsense, so was your post after that.
Read it over & over. Let's not ruin this nice thread.
If anyone wants to speak about invaders or clarify my sim-questions It would be nice.
Edited by tv00 - 29 December 2014 at 12:26am
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2014 at 12:28am
id say, mikeys sims are correct.
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2014 at 12:45am
Any explanation for that?
Or just more discussion spam?
I refer to the sims posted in this thread
I also ask several questions about the input data for these.
I am serious about my posts.
I don't feel like reposting these again.
Wonder what Input data mikey is using, no actually I wonder what input is the correct.
I posted the new version of nineleaves sim of 1 box in corner, it's far from Mikeys version.
One reason not to thrust Mikey is that he's making money selling c4 & his always claiming to have the best whatever speaker IN THE WORLD! WHOW!
Edited by tv00 - 29 December 2014 at 12:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2014 at 12:55am
well actually I added some length to the Invader. I made it 2 meters instead of 1.8-
my sim was with a different driver sw115
Mykey Wattco
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2014 at 12:58am
Mykey Wattco
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2014 at 1:02am
I guess you must be right!
The first sim in that post must be the old version, the next two the new version of the sim. VERY CONFUSING with a semi-updated post containing old & new sims!
I've seen several versions of this sim:
-some takes the air in front of the cab into account & "sees" ground.
-some uses "tra"=tractrix.
which is best?
Last thing I don't get is where the horn starts? Is it in front of the driver or after the last opening?
You're right I should build a proto, first I have to decide which!
I build quite some boxes though, other boxes:-)
Edited by tv00 - 29 December 2014 at 1:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2014 at 1:21am
Not sure if a new sim was done since all of the modifications. 20 litres is cone volume, plus all the area in front up to the first bend
but now there are lots of holes, so now this will take the front chamber volume down to around 4.5 litres
black is 4.5 litres. grey is the original 20 litres
Mykey Wattco
