sb1000 eaw |
Post Reply | Page <1234> |
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Think EAW SB1000 is a dipole reflex design.
TDA-Audio
Registered User Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
EAW SB1000 plans-
http://www.igolkin.com//soft/Tda-audio/upload/EAW-SB1000.pdf |
omari7
Registered User Joined: 08 September 2005 Location: United States Status: Offline Points: 23 |
The EAW BH882ip drivers by RCF are no longer available. Does anyone have an idea of what woofers would be a good replacement. I own two EAW BH882ip, and I am looking for two more.
Omari ar49@nyu.edu |
Omari
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
If those are really the plans for a SB1000 then it is a BP6, not BR.
In addition to that the SB1000 is pretty inefficient. Only 95dB 1W/1m! Yes, both 18s driven. |
norty303
Or somewhere in between, that manifold is very negligible
ceharden
The plans which have been floating around on here are NOT the SB1000.
It's lacking the large central port which they have common to both
drivers. I know cos I've had the grill off one and stuck my arm
in it to see how far it goes!
tslson
Registered User Joined: 27 January 2008 Location: Canada Status: Offline Points: 1 |
do you have a plan for sb-1000 eaw
tech sound and lighting show
mylesound
Registered User Joined: 08 August 2007 Status: Offline Points: 351 |
3 years ago i hired 6 of them to take care of the rear of my truck for NY carnival. sounded crap compared to only 4 single 18 foled horns i used last year. |
SURINAME
Registered User Joined: 06 February 2008 Location: United States Status: Offline Points: 16 |
CHECK THIS OUT!!!!!!!!!!!!!!!!!!!!!
http://www.snakepro.com/pdf/proj/projeto_18_01.pdf BETTER LATE THEN NEVER ENJOY................ |
SURINAME
sirck50
Registered User Joined: 01 August 2006 Location: Trinidad and Tobago Status: Offline Points: 126 |
THAT LINK IS not THE sb1000 PLAN. Anyone knows how the central port is built? Dimensions?
Hello!!!
kumar
New Member Joined: 14 February 2011 Location: punjab Status: Offline Points: 2 |
hi all i also need same plan but i got some pics its not eaw sb 1000 but similar to this
