TH-Mini - tapped horn - by Danley Sound Labs |
Post Reply | Page 123 12> |
TDA-Audio
Registered User Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
Posted: 02 September 2008 at 5:44pm |
Hi all
who made this cabinet ??? that say ? where take plan? http://www.danleysoundlabs.com/tapped_horn.asp?MODEL=TH%20MINI |
mykey
Old Croc Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
MarjanM
I think it looks like this
Jake_Fielder
Thats a pretty good guess i reckon,
TDA-Audio
\\\\ looks like this\\\\\
to Marjan...yes, approximately... where take detailed plan??? what driver use??? |
Deadbeat
Close, but no cigar, Mykey. I would reckon that would be a bass reflex meself...tapped horns function quite a bit differently I think. Ah, but many years ago there was the Jensen transflex and JBL air coupler and EV T18, though, I think? But then again none were exactly a tapped horn by any means...
TDA, as with all (excluding the Labsub) of Tom's designs, he does not give you any plans (unless you are as unchivalrous enough to open a box and post a plan, unlike most designers he is an active force on the internet), but instead dispenses lots of easy to find advice on designing such horns, indeed you can design one quick in hornresp, and I believe djk has designed a bin of similar proportions taking a 12. Good day. |
Away on extended leave.
Disco Stu
Yep I think Tom doesnt try and shroud his products in secrecy like some. He knows that if people want to find out how a box works they can just open it and see. That doesnt mean they can copy it and get a good sound though. He knows this which is why he appears honest and open about the theory.
Stu |
All you need to know is:
Deadbeat
An interesting TH-mini alternative plan by Patrick Bateman:
http://www.diyaudio.com/forums/showthread.php?s=&postid=1601818#post1601818 |
TDA-Audio
\\\\\An interesting TH-mini alternative plan by Patrick Bateman:
http://www.diyaudio.com/forums/showthread.php?s=&postid=1601818#post1601818 \\\\\\\ not plan... only test sub,s ... |
TDA-Audio
\\\\\\\\\\\\\\\\\\Danley Sound Labs TH-mini - List $1295 ($1425 for flyable version)
I was quite impressed with the amount of low-end that came out of these boxes. They aren't much bigger than most computer towers and yet they would fill the room with a nice pleasing low-end. Their response does drop off down really low but they should work incredibly well for anyone looking for super compact but great sounding subs. As Ivan mentioned, these are geared for super portable systems or space constrained installs.\\\\\\\\\\\\\ |
Deadbeat
That's all you will be getting off the internet, I'm afraid, that, and djk's sub. There are no plans, (even if there were, I wouldn't link to them as it directly contradicts the rules of the forum asking for current production models). Asking for Danley sound labs plans is akin to asking for Funktion one plans...only the man tells you how to design and make boxes operating under similar concepts. You have to make your own plans from the hornresp inputs. I believe djk has a rough diagram of his TH-mini alternative. |
TDA-Audio
my version Tapped Horn
still http://www.danleysoundlabs.com/tapped_horn.asp?MODEL=TH%20MINI based plan Staip http://speakerplans.com/forum/staiper-design-for-learning-hornresp_topic24297.html I calculated... wide resize... |
