TH-Mini - tapped horn - by Danley Sound Labs |
Post Reply | Page <1234 12> |
jethrocker
Interesting TDA... how does it sound..any measurements or even just simmed response?
edit: OP name confusion. Edited by jethrocker - 12 June 2009 at 10:19pm |
S.A.L.S.A
Registered User Joined: 15 June 2008 Location: Aruba DC Status: Offline Points: 21 |
How are the results in comb. with the NEXO LS1200 sub??
Does it goes louder and deeper??
Nice bin!
Dave
Get to the Point with L'acoustics Dv-Dosc!
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
I think he doesn't use this bin in combo, probably he has stacked on a nexo to facing the external dimension. Just IMHO
Ibex
Young Croc Joined: 27 May 2009 Status: Offline Points: 1013 |
Very nice!!!
TDA, which driver do you use in your cab? How does it sound? Did you make a comparison to the original th mini? Does your design play deeper or loeder than the one from tom? Measurements would be very interesting! |
TDA-Audio
Registered User Joined: 11 February 2005 Location: Russian Federation Status: Offline Points: 294 |
inside 18" version
jethrocker
Very nice ... but we still want answers :)
Ibex
Seems that TDA's real intention is to give us some philosophic thoughts
Although i'm as well very strained to get some auditory impressions from TDA corresponding on the 12" and the 18" modified tapped constructions. Edited by Ibex - 16 June 2009 at 7:50am |
Father-Francis
TDA write in Russian we will translate , no worries I´l speak for some of us we getting more outernational |
TDA-Audio
yes . I Max Peshkov has reported on forum
18" version - full still Staip
12" version - recalculated ....
i used
I am a test driver"s - p-audio p-120\130Lf
B&c 12nw100
Ciare 12.00sw Beyma 12Lx60 P-Audio SD-12EL
and 18"
18lw1400
18tbx100
18" cabs - good pressure, but big weight.. (for 18tbx100).
18lw1400 - no good work..
12"cab - ciare - very big pressure!!
12"nw100 - good, but much loses ciare...
12LX60 - Very Good. SD-12EL - good.
12 versions -preference...small size! and good pressure for their own size Tapped Horn and Scoop"s - different cabs ... Edited by TDA-Audio - 17 November 2009 at 8:36pm |
TDA-Audio
LS1200 vs TH 12"
12" 48hz -6 db.
ls-1200 32hz -6db
pressure th-12" vs LS1200 (street)
for 1 m - ls1200 more pressure
but 15-20m - TH-12" vs Ls1200 - approximately equally pressure.. |
Ibex
First of all: TDA, thanks for answering!
I think the 12NW100 has the same parameters as the 12PS100 but with neodym instead of ferrite? Isn't the response of the 12" version loaded with the Ciare a little bit peaky in comparison to the B&C? Did you annoy the minimum at 80Hz when you were listening to music and/or made your comparison/measurements? That is, what the simulation says: black = B&C 12PS100 grey = Ciare 12.00SW |
Ibex
TDA, i'm not able to reconstruct what you said, my results are nearly congruent with both drivers... black = 18Sound 18LW1400 grey = B&C 18TBX100 |
