2x18 manifold box |
Post Reply | Page <123> |
luc2366
Registered User Joined: 09 August 2006 Location: Belgium Status: Offline Points: 16 |
"the Deltamax clones from SSE will work well whiad DAS G45"
I'm very sorry: I heard them loaded with D.A.S and it sounded like sh*t...
"The idea, that it works only with EV's drivers and setups are totally wrong!"
Correct, I use Beyma-drivers and a DCX-2496 and my (8) cabs sound great
Here you can find some pics:
Bye the way, I know Nikki van den Bosch - he's also from Belgium. He's MTL-2's loaded with Eminence (and also using a DCX-2496) sound great!
Hugo Biermann
Young Croc Joined: 05 February 2005 Location: South Africa Status: Offline Points: 809 |
Have used OEM, eminence and p-audio loaded MTL2's. With anything from
utradrives, Driveracks to the ev processors. 40Hz - 80 / 85HZ without
EQ. Theyre loud and for some reason throw quite far outside. They take
plaster off walls in club setups too... f**k them with power though.
Hugo Biermann
And I have seen a LOT of half MTL2's that rock parties into jail almost. With normal analogue x-overs. Theyre great boxes. Build them if you want. They can be heavy on yr back though...
Hugo Biermann
Heres the plan of the 'half MTL2' thats going around here. The get loaded with all sorts of 18's. the most common ones are:
Eminence Omega 18's & Kappa 18's P-Audio C18-650's & E18-400s' All depends on yr amplifiers and applications. They all sound gret too. Don't try to model them either. It doesnt work. f**k knows why, but the boxes work... |
simo69
Old Croc Joined: 29 September 2005 Location: United Kingdom Status: Offline Points: 1890 |
Does anyone have a photograph of the finished item?
Is there another angle to this drawing??
Hugo Biermann
Thats what I got off an emty cab with a tape-measure. Will try and ge a photo of 1 when I see 1 again.
If you want a different angle, turn the left-hand side square 90deg to the right and then u have the position the box is supposed to be in when you play it. |
simo69
what is the overall 2x18" sizes. |
simo69
what is the 2x18 dimensions
Hugo Biermann
luc2366
...and here for the pictures:
MARTYNJONHALL
Registered User Joined: 02 January 2005 Location: Burton On Trent Status: Offline Points: 335 |
these cabs look great anybody got some detailed plans for them??
vertigo
Registered User Joined: 19 December 2005 Location: United States Status: Offline Points: 54 |
I'm interested in building these too, any plans? The speakerstore link only has a picture.
