Super Bass Horn V.02 by Startec (Quad Acoustics-F) |
Post Reply | Page <1 3738394041 46> |
Author | |||
Strawberry Jam Sound
New Member Joined: 06 March 2017 Status: Offline Points: 8 |
That's good to hear thanks! The tent is quite small so we shouldn't have to run them too hard so hopefully heat wont be a problem. Ply arrives on Friday, can't wait to get started. Anyone got any building tips for these? We're not experts by any means but managed fine building mt121s, hoping these won't be too much more difficult. We planned to make a jig in order to rebate the sides using one of those bushing for a router and a template just to make sure everything slides into the right place. We thought to remove the back bottom corner too and make the 45 degree piece double thick to put wheels on so we can just tip it back onto the wheels :)
JohnnyKarr
New Member Joined: 18 September 2015 Status: Offline Points: 8 |
Hey guys, wiring up my subs.... do i have to reverse wire it since its facing backwards? Ie. +1 on the input to -1 on the driver and -1 on input to +1 on driver? Thanks!
The driver doesn't go in backwards, the cone faces the air through the horn if that makes sense, so you don't need to wire it backwards. You'll need to delay your other boxes appropriately to account for the 3m horn length
djeddie
Wire it as normal, (+ to +, etc) and use use your LMS to control the phase.
JohnnyKarr
Thanks everyone!
What have people done in the way of cladding on the inside of the box?
Thanks |
SouthwestCNC
The amano sim looks awesome. One question whats an amano? Tia |
tv00
tv00
Also have a look at this:
https://forum.speakerplans.com/alternative-version-of-wsx-plan_topic35203_page2.html EDIT: Also no 180 degrees bends, the way I like it :-) Double edit: I'm not very fond of the SBH dip at 50hz, some popular deisgn I never really get, same counts for cubos (not sub not kick) and bfm tops :-) Edited by tv00 - 06 October 2017 at 1:29pm |
tv00
Then I also have some questions to add to the confusion, two things I've never really understood:
Phantom horn: When is this being accounted for, I thought hornresp would do so itself doing a sim halfspace, but the invader sim I think includes the phantom horn. Is it automatically in hornresp sim? https://forum.speakerplans.com/2x18-meatgrinder-v2-done_topic29174_page13.html Manifold horn: On some threads it's simulted like two horns shraring the full area of the joint part of the horn, others simulate splitting the joint part of horn, that then has negative expansion, i guess it should be one step down in Pi then? Edited by tv00 - 06 October 2017 at 1:38pm |
Quadradub
New Member Joined: 24 October 2017 Location: São Paulo Status: Offline Points: 2 |
Bless you my friend i'm looking forward to get my hands on that pdf file that you linked on your first post with the SBH plan. Can you re-upload it please?
Quadradub
Someone has a plan for the Tera Horn and it is possible to share it with me? Bless you!
