ES18-BPH |
Post Reply | Page <1 2829303132 35> |
soundsystemdan
Young Croc Joined: 04 April 2005 Location: Leeds UK Status: Offline Points: 716 |
60Hz is fine, even 50 if you have two.
You might want to reverse the polarity, but phase alignment is so complicated it could go either way. Try +/- and see which is loudest. If you can't tell, then your delays may need adjusting. |
soundsystemdan
it doesn't matter. Pick one and stick to it. I reversed it on the driver. |
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
Cool! Thank u for the reply :) will try dropping them from 70hz to 60hz and see difference. Its what I thought about reversing polarity I just wanted to check. As regards to waddig do u think I will get away with just wadding the access panel.. Not too thick tho! Thanks buddy :)
tv00
I'm so amazed by my turbosound tsw-218, they do really frop low, we even measured it!
I don't know how, but it works, it's a bit bigger though, approx same size as TT1000 think it's something like 57x70x75 (per 18", there's two) |
Marko
Registered User Joined: 28 January 2009 Location: Croatia Status: Offline Points: 274 |
tv00, can you tell us what drivers tsw 218 are loaded with?
I never had a chance to hear them but lots of people here saying that they go lower than usual for the band pass horn. I would really like to know what driver Turbo use. Not for copying purpose but out of pure curiosity. |
bass*en*mass
OEM fane/pd i suppose..
tv00
Yes, originally it was a pd first called turbosound ls-1812, then 1812.2 that had an extra reinforcement ring between coil & cone under the centerdome (and a big centerdome) as some of the drivers ripped their cones. I think this was mainly due to the fact that people use them standing vertically in singles thereby unloading them at low frequencies.
RC-kits are unavailable and turbosound changed to a new B&C driver called ls-1815, this driver looks identical to me to NBX100 more than 18nw100 as the first one has no cone threatment an neither does the ls-1815. But it could be turbos own version as the wattage is low on the turbo tsw-218 (the pd made ls-1812 & 1812.2 has tiny windings on the voicecoil) The drvers are loaded with magnet in horn like es18 (& plans are online) When changing to the b&c made ls-1815 you have to use an adaptor ring or make new holes, this thing puxxles me a bit, the adaptor ring is at least 18mm so it must change rear / front chamber by some litres compared to new holes, I don't know what's best. |
tv00
bass*en*mass
"When changing to the b&c made ls-1815 you have to use an adaptor
compared to new holes, I don't know what's best."
easy to calculate the volume of that adaptor ring if you want to know for sure, personally doubt a change of +- 1l of chambers makes a noticable difference anyways, specially not with bigger driver possibly eating up extra volume in the front chamber :) ts parameters might be slightly off the other drivers too to make up for any physical changes required to fit that new driver? > have you compard both versions 1:1? |
tv00
No, but both mounting with & without ring is "officially" used, I just found that a bit strange...
If dia=50cm, thickness 2 cm, volume is 4 liters Edited by tv00 - 30 December 2015 at 10:57pm |
Dub Specialist Sound
Ive built and building some of these cabs, but had no time at all to do testing
so is it best to putting wadding on the access panel and on the inner sides? ive only picked up on wat Bee said about the wadding , any more opinions thanks...
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
I do
