  New Posts New Posts RSS Feed - Hog Scoop, a few questions
raspix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote raspix Quote  Post ReplyReply Direct Link To This Post Topic: Hog Scoop, a few questions
    Posted: 11 February 2010 at 10:15pm
Hello,
my mates & I are planning on making these HOGs, and we had a few questions on the construction, and on the speaker that'll drive 'em:
There's another plan with the rest of the mesurments, but I wanted to know if anyone had ever build these, and what's to think of it ?
Second question, it is said on the plan that a B&C Speakers 18TBX100 would be good, is that info any good ?
What do I need to use to cover the inside of the cab, glass wool ?
and last, the type of wood is specified on the plan, would another kind do the job (MDF for example) ? and double bracing the whole cab means every piece of wood that'll be put inside it must be screwed through a brace ?
That's about it,
pleasant evening to you all
Edited by raspix - 11 February 2010 at 10:27pm
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2010 at 9:28am
Edited by king david - 03 February 2014 at 7:55pm
jossdude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jossdude Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2010 at 10:19am
Double bracing means that there should be two identical braces accross the width of the design, rather than just on in the middle.
A picture says a thousand words,
Makes them look rather pretty with the double bracing to!
Post Options Post Options   Thanks (0) Thanks(0)   Quote raspix Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2010 at 3:28pm
thanks to you two for the quick answer, would you have by the way some pics of the construction of these ?
bless
nomis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomis Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2010 at 3:41pm
read the hog scoop thread(nice pics by father francis in there),and a more recent rebated build.search 'hog scoop rebate' in the forum.
Autograff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Autograff Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2010 at 3:59pm
Go for PD1850 or V18-1200 if you want serious low-end grunt .
Liquid_Steel_Sessions
R8 Records
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2010 at 2:34pm
serious low end grunt yesterday night
room didnt have best sound, or cabs werent placed in best position so dance floor had very nice bass but outside the room everything was shaking hard, nice throw!
briansmusic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote briansmusic Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2015 at 2:56pm
Hi, I was wondering. If the PRV 15SW2000 Subwoofer will work in the Hog Scoops well?
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2015 at 3:17pm
Its a 15 inch m8 you could probably get away with it but with not so good results,check out the micro scooper also from staiper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote briansmusic Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2015 at 3:33pm
Ok thanks man... Handshake
Post Options Post Options   Thanks (0) Thanks(0)   Quote briansmusic Quote  Post ReplyReply Direct Link To This Post Posted: 19 December 2015 at 3:37pm
I jus view them online an they are the same as the hog's
This page was generated in 0.047 seconds.
