  New Posts New Posts RSS Feed - Some General Amp Qs
Some General Amp Qs
Speaker Sol View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Topic: Some General Amp Qs
    Posted: 02 June 2010 at 9:33pm
Hello, couple questions on my mind.
Testing amp output, I have a fair idea, but would like to be told before I go messing.
How do you check for DC on the output?
Also, Over the years I have come across a few amps that, "pop" when you turn them off.
What courses this?
Thanks.
Symzzi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Symzzi Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2010 at 9:37pm
Multimeter + probes + eyes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2010 at 9:43pm
Probs across the out put, looking for DC voltage.
Thanks thats what I thought, but thought I better check before I go probing.
If I run an a sine wave through the amp and turn the multimeter to AC, I Should be able to read output voltage?
abbotsmike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbotsmike Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2010 at 9:50pm
dependent on the multimeter. if it's a 50hz sine wave, then I believe any meter designed for standard supplies will do the trick and give a rough reading.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2010 at 10:14pm
Thanks.
So any one have any ideas about the "pop" noise that accompanies certain old amps, when they are switched off?
Louder than loud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louder than loud Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2010 at 3:41am
That would be due to no ''soft start'' which is something all all new amps now have / come with.
Hope that's helps and if it doesn't have a look around google.
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2010 at 7:06am
what kind of meter should be used to measure output voltage with other frequencies than 50hz?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2010 at 11:26am
Thanks, I don't think it is a soft start issue, a friend has a pair of amps, only one does this.
But you are right, I will google it.
Thanks
Edited by Speaker Sol - 05 June 2010 at 11:27am
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2010 at 11:57am
"only one does this."
Caps are shot.
"other frequencies than 50hz?"
True RMS voltmeter.
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2010 at 1:13pm
Caps discharge suddenly on power off, meaning they can no longer hold charge for more than a few mS?
AvLee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AvLee Quote  Post ReplyReply Direct Link To This Post Posted: 07 June 2010 at 11:12pm
Thanks.
You'll find a lot of speaker management systems/processors do this as well so don't forgot the, "last on, first off sequence" for the amps when your switching all your gear on and off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Speaker Sol Quote  Post ReplyReply Direct Link To This Post Posted: 07 June 2010 at 11:23pm
Wink
Thanks
This page was generated in 0.111 seconds.
