MTH 4654 |
Post Reply | Page <1234> |
FlipC
Young Croc Joined: 25 October 2007 Status: Offline Points: 654 |
Nice build.
Beatdaddy
Registered User Joined: 28 November 2010 Location: California Status: Offline Points: 340 |
I'm going to fire it up tomorrow! A lot bigger than the ms-18's.....
Tony Wilkes
I hope you wear riggers gloves when moving them!!!
Tony |
Drimacoustic
Registered User Joined: 01 July 2006 Location: Slovakia Status: Offline Points: 132 |
You should definitely round over the handles also from inside. Nice build though, let us know how do they sound. I think that Sigma is not the best choice of driver for this cab.
love begins below 40Hz
Beatdaddy
Tried two drivers out today:)
The sigma sounded awesome ... Reminded me of the x-1 but goes a little farther up. Crossed at 30 hz highpass 120 lowpass , this is a loud box! Then i put a cheap ebay driver zyp-18 in that i had in a sub 18 for about a year, almost as good ! crossed at 35 hz highpasss and 110 lowpass, WOW! I'm getting a c18-650el reconed , I'll try that next...... Also I'm using a driverack pa and a crown xls 402 bridged for these tests... Overall this thing is amazing , but then again .... It is GIGANTIC!!!!!!!! P.S. Thanks for the tip on the handles:)
VentureSound
Young Croc Joined: 18 October 2009 Location: London N20 Status: Offline Points: 950 |
I've just been testing two MTH4654 that were made for me by Tomschute, and very nice they are too! I've loaded them with Eighteensound 21LW1400, and after doing some early listening tests, I don't care about the "wasted space". Actually, if you think about it you could use that space, let's say for an active amp module?
So, more details about the sound of the cab: I was comparing one cab of the MTH to one box of our BPH double 18s which are very similar to an F218. For most jobs these do very well, and i'm happy with them, but wanted to try something new, (and with more sub) hence the MTH. Physically the boxes are about the same volume, so a bit of a comparison is useful I think. Ok, so there aren't really many suprises here, but audibly the F218 appears louder for the same input signal (so we are comparing 2x 18" to 1x 21"). Actually the 218 is not that much louder, the single 21" does very very well against the two 18s. Could the extra perceived volume from the 218 be distortion? On paper they have a similar sensitivity, around 103db for MTH and 105dB for the 218. The 218 has a harder kick, no suprise there either. The sound from the 218 hits you in the chest, whereas the MTH does not. You can hear the kick from the MTH its just not as strong as the 218. The transients from the 218 are audibly quicker and more punchy. Now, for sub the MTH clearly wins. The bass notes from the MTH sound very clean and a single cab sounds like it plays lower than the 218, which it probably does. The sound from the MTH is very pleasant to listen to on its own and is non fatiguing, which a 218 can be at full chat. To be fair to the 218, I normally use these in stacks of three, and they sound pretty good like that, with enough 'sub' for most applications. Overall I really like the sound of the MTH. It produces lovely clean bass and there is no honking or colouration that I could hear. I played a variety of music through the cab and could hear basslines going up and down, each note clearly distinguishable from the other. Sounded like the response was pretty flat with no nasty peaks. I was crossing from about 25Hz to 120Hz. I spoke to Marc the designer and he suggested some EQ to liven up the kick. That's what i'll try next. What i'd really like to do is hear a stack of eight of these driven by a pair of Crown IT8000s, which should be something quite fun indeed! Tom, i'll be in touch shortly. Below are a few photos of the finished MTHs. Sorry about the pic quality but I had to do them in a hurry with my phone. I will also try and put some better ones up later, from when they were being made by Tom. Uploaded with ImageShack.us |
VentureSound
Where are the sockets for input! |
JDCutta
Registered User Joined: 24 June 2010 Location: North Lincs Status: Offline Points: 555 |
Im guessing in the recess on the back of them, just looks like the holes aren't cut yet
tomschute
Old Croc Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
there the new wireless neutrik series
www.stableaudio.co.uk Speaker Building Services |
VentureSound
Haven't you heard Toasty? Neutrik developed the new wireless series after Tom developed the Inductive Synergy Drive (similar to the Toyota Prius, but a lot less shit). You just sit the cab next to the amp, and it knows what to do!
Beatdaddy
Putting a beyma 18g550 in next!
