MTH 4654 |
Post Reply | Page <1234> |
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
looking good
i want to build some of these and load them with 18 Sound 21NLW9000 and give each cab around 3.5kw it will be an expensive venture but do peeps think it will be worth it? |
CELTIC SUBSONIC SOUND SYSTEMS
staiper
Registered User Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
_____________________________________________________________________________ Following one might be not to bad (HR simulated in same combination with same speaker unit) considering that cabinet will be 123ltr. smaller |
Just do it! ..or do not.. ;)
djeddie
So what cab is that then? |
staiper
..some ~3Hz less low extension than MTH4654 CBX-18 |
djeddie
Thanks Stipe.
tomschute
Old Croc Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
Yo Stipe...
Would you be helpful enough to share HR data for CBX? What sort of drivers work best? regards, Tom |
www.stableaudio.co.uk Speaker Building Services |
staiper
S1 = 800 L12 = 21 S2 = 756 L23 = 208 S3 = 2600 L34 = 30 S4 = 5455 |
Beatdaddy
Registered User Joined: 28 November 2010 Location: California Status: Offline Points: 340 |
Tried the beyma in it ..... Sounds awesome!
Was keeping up with a jbl vertec powered unit , with only a crown 402 bridged!!!! Thats only about 800 watts into it...... Im on a hunt for the 21n451...
_djk_
djk
Beatdaddy
Beatdaddy
WOW!!!! I really like that driver, need a few more . MS-18 is still the best sounding scoop i've heard , especially with the beyma !
Beatdaddy
This box likes the beyma!
