Amp Internals 2 |
Post Reply | Page 123 260> |
kedwardsleisure
Posted: 03 November 2010 at 5:36pm |
Peavey GPS3400
peavey by Electro Mechanic, on Flickr Edited by kedwardsleisure - 06 November 2017 at 8:08pm |
North Staffordshire |
subbass
Cloud MPA 626
swannie
Registered User Joined: 15 March 2008 Location: WEYMOUTH Status: Offline Points: 276 |
Gemini XGA4000 power amp / 2x350w @4ohms (not 4000w as the front panel suggest's!!)
Dunlap Clarke Dreadnaught 1000 (mid/late 70's) 2x500w @4 ohms (weighs a ton!!) Edited by swannie - 20 November 2010 at 9:44am |
Wrighty
Old Croc Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
Hz DPX600
Oldmaelstrom
Registered User Joined: 07 October 2009 Status: Offline Points: 15 |
Dynacord AM12
Edited by Oldmaelstrom - 16 November 2010 at 4:29pm |
Jez_3phaze
Registered User Joined: 31 August 2009 Location: Derby UK Status: Offline Points: 162 |
Similar to Wrighty's Post! /\ Quote picture removed, Apologies K.
My RDL PX 1100
550w RMS Per Ch@ 4 ohm /1140w RMS Bridge @ 8 ohm. Edited by Jez_3phaze - 17 November 2010 at 12:05am |
kedwardsleisure
Do you think that posters can withold from quoting the previous post if it contains large pics, like the last example? I find the multiple repeated pics confusing.
Edited by kedwardsleisure - 16 November 2010 at 11:46pm |
Wrighty
Hmm, a remarkable likeness, yes! Heatsinking looks a bit better on the RDL. It looks a lot cleaner too. This Hz has had its front panel hand painted around the gold lettering with what looks to be black gloss Hammerite! It was given to me to look at by a colleague and may or may not have a fault... |
Grumpy
Registered User Joined: 16 January 2007 Location: Lichfield Staff Status: Offline Points: 405 |
On that Dunlap Clarke Dreadnaught, the switch on the back marked “Max off Min”. Does it switch transformer secondary windings to give different power outputs, like the old Midas Cube Monitor Amps? Edited by Grumpy - 17 November 2010 at 3:42pm |
swannie
No the switch is for the fan on this amp, you can adjust the speed or simply have it turned off
Monitech
Registered User Joined: 19 February 2008 Location: United Kingdom Status: Offline Points: 78 |
Hmm, a remarkable likeness, yes! Heatsinking looks a bit better on the RDL. It looks a lot cleaner too. This Hz has had its front panel hand painted around the gold lettering with what looks to be black gloss Hammerite! It was given to me to look at by a colleague and may or may not have a fault... now as john savage used to be a sales man for HZ
and martin savage used to own RDL does this not suprise you that they are simalar regards
phoenix out of the ashes
Grumpy
Thanks, was just curious |
