Help with a Zeck PT7 |
Plaguesguitarist
Old Croc Joined: 30 April 2009 Location: Lincoln, Earth Status: Offline Points: 2238 |
Posted: 09 February 2011 at 8:34pm |
Bought this amp a while ago off ebay for £20. It was in a bit of a mess although i have done some repair work on the power supply board. I've reconnected the supply board jumpers and the transformer connections as per the schematic and reconnected the speakons sockets hence the untidy state of the wiring which will be cable tied later. It will be going in for a full repair as soon as i can decipher whether it is actually worth it or not. Here's the internal...
What i need to know is: does anyone have any particular experience with these amps?
Pictures i've seen on the internet show a model with a replicated but reversed supply board on the other side of the transformer but i think that is the PT9.
Can anyone confirm this theory or whether i should have the second supply board, thus likely rendering this as scrap.
(just to reiterate i will be putting this into qualified persons at panic audio before i plug it back in - i'm not quite suicidal just yet)
Thanks
To steal MY sharpie. |
andyamp
Old Croc Joined: 21 July 2007 Location: United Kingdom Status: Offline Points: 2115 |
not seen one of them for a long time
a wise man changes his mind a fool does not.
http://www.matrixamplification.com/ |
pirate
New Member Joined: 22 December 2014 Status: Offline Points: 1 |
hi i have just got a zeckpt7 but the inpt signal in the direct out and it went with a flash and a pop and its doesent work any more it turns on is it fixable or is it fucked
DIGIMAN
New Member Joined: 26 October 2014 Location: INDIA Status: Offline Points: 4 |
file:///C:/Users/Andrew/Downloads/Zeck-PT3_5_7_9%20amp.pdf
djeddie
Somehow, I don't think that link is gonna work... unless your C drive is open to the entire world wide web. |
DIGIMAN
http://www.eserviceinfo.com/downloadsm/54218/Zeck_PT3,%20PT5,%20PT7,%20PT9.html
