Increasing size from M6 to M8 T nuts |
dnbpc
Registered User Joined: 18 March 2010 Location: Manchester Status: Offline Points: 381 |
Posted: 07 September 2012 at 5:43pm |
I've recently had some Hogs built but they have been t-nutted to fit M6 bolts. My PD1851s arrived today and they require M8 bolts, what is the best way to increase the size of the hole so I'm able to mount the drivers?
spongebob
Should be a peice of "pee" to sort with a hog, no?
Take the old driver out, remove existing tnuts, redrill with 8mm bit, offer up the new 8mm tnuts and then clamp them into the wood (G Clamp or such) Edited by spongebob - 07 September 2012 at 5:50pm |
JR.junior
+1000 |
dnbpc
Cheers thought it'd be a simple job just wanted to make sure.
jacethebase
Just make sure that the new tee is seated properly.
www.stage2sound.com |
infrasound
This! you don't want the last tee to fall out Run around them all first with a washer instead of the basket, with an electric drill you can get them to bite fully in no time
grazzeee
Registered User Joined: 06 July 2011 Location: Portsmouth Status: Offline Points: 440 |
i literally just finished the exact same job.
did 4 hogs, last hog top t-nut i think has poped out, its not gripping! so pissed off. left it to change on a rainy day my screw driver ran out of battery!! lol
think you need a 10mm drill bit for m8 tee nuts.
dnbpc
Just got round to doing this today and the m6 t nuts aren't moving when trying to get them out, whats the best to remove t nuts? Or will i be fine mounting the PDs with m6 bolts?
infrasound
Put a bolt in them, and batter it with a hammer.
JohnnyPyro
Old Croc Joined: 17 November 2008 Location: London Status: Offline Points: 2083 |
and when you seat the new T' nuts use a big packing washer on the bolt head side, otherwise you could risk damaging the baffle with countersunk holes
Edited by JohnnyPyro - 29 September 2012 at 1:33pm |
Powered by MC2 & XTA |
shagnasty
I'd always put grease or copper slip on the bolts as i fit the driver, spinning Tee nuts are a a pain!!
