  New Posts New Posts RSS Feed - Celestion CF18VJD vs PD1850
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2012 at 6:07pm
Bee so the  CF18VJD will fit in the superscoop cabinets?
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2012 at 6:39pm
Never tried them in a super.... will check measurments for you...
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2012 at 7:19pm
ok give thanks
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 2:17pm
ok from front of baffle to rear panel on a super is 256mm the cf18 is 233mm so it should fit fine.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 2:45pm
ok give thanks maybe ill try a couple of them see how they beat
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 5:47pm
No.
From Front of cabinet to rear baffle is 256.
From Front of front baffle to rear baffle is 220
Inside depth of chamber is 202mm (256 - 54)
Celestion is 233 overall depth.
Assuming Depth behind front edge of driver is 223mm,
Then it seems driver is 21mm too deep.
Edited by levyte357- - 01 December 2012 at 5:48pm
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 5:59pm
you are correct lev.... sorry up and coming, i looked at the orig plans in a rush..... ive had a bad dose of man flu for the last 2 days so me head is a bit fuzzy.... sorry....
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 6:06pm
No
Driver capacity is 220 in the super because it sits on the outside of the front baffle
So the celestion is 3 mm too deep. Add the 5mm you need for clearance, the driver is 8mm too deep. But you could rout this out of the rear baffle.
Edited by SBC - 01 December 2012 at 6:08pm
F.T.S.S.
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 6:10pm
..or buy a PD186.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 6:15pm
the other option is to but on a double front baffle..... or build new ones with bigger chamber....
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 8:41pm
ok give thanks ill keep using my celestin bx 18 in them
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2012 at 10:49pm
Originally posted by SBC SBC wrote:
No
Yes, Saul, dat is it.
This page was generated in 0.328 seconds.
