  New Posts New Posts RSS Feed - Beyma 12P80/Fe
Beyma 12P80/Fe
mrspock100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrspock100 Quote  Post ReplyReply Direct Link To This Post Topic: Beyma 12P80/Fe
    Posted: 18 January 2013 at 4:46pm
Is the 12P80/Fe a bass/mid or midbass driver?  Will will it work as fullrange in 2 way in fane box 12 cab or is it more of a mid driver?
spttrial View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spttrial Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2013 at 10:39am
The Beyma 12P80Fe is a High effeciency Driver, good midrange performance with a adequate amount of Bass content, It can typically be used in full range box's like stage monitors, front of house PA with either a 1" or for more headroom in the driver a 1.4" driver.  This will certainly do what you need it to do.
30 years in the business
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrspock100 Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2013 at 10:13pm
I'm planing on using the 12P80Fe in the fane box 12 cab with a RCF HF101 flare and BMS 4538 1".
hope this will work together?
Post Options Post Options   Thanks (0) Thanks(0)   Quote spttrial Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2013 at 11:47pm
Hi yea, that'll work fine. But for 2 x12" of this kinda sensitivity a 1.4 inch driver would be better. Take a look at the Beyma cd1014fe and one of the Beyma horns to go with it. Are you running it active or passive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrspock100 Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2013 at 12:04am
Custom passive x over at 2k and the BMS 4538 is 60 W AES, 114 dB
TENSiON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TENSiON Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2013 at 9:04am
Wacko
Don't get fooled by that number as for some odd reason BMS decided to pull a "soundlab" on that particular figure.
When you look up the plots on the official website, you will notice that it is merely the absolute maximum PEAK, reached at around 2.5kHz, and even there it is just barely licking the 114dB mark from bottom.
The average sensitivity within the usable frequency range would be closer to about 107dB/1W/1m.
The bottom line being, that even though the BMS 4538 is a great budget driver, one can not expect miracles from it Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote spttrial Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2013 at 10:10am
Ok, 2k passive is a safe enough area, But as tension says, you might be better of with a driver that has a flatter responce, so concentrate on the curves, and not the big numbers, Bear in mind that as a passive box you are going to have a 4 ohm load on the bottom end, and these drivers can take a good whack of power, so your passive components are going to have to be pretty meaty to handle to power given to the box.  If you think you are going for a 1" driver, theres loads of choice out there, The 12P80fe driver is a quality item, and a good choice for this type of box, so dont spoil it just for a £10.00 cheaper 1"  try Beyma's CD10ND or maybe CD10FE
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrspock100 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2013 at 1:11am
The BMS 4538 is a good quality 1" and goes load with ease. It's loud mounted on the RCF 101 horn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrspock100 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2013 at 1:15am
I mean loud
This page was generated in 0.152 seconds.
