  New Posts New Posts RSS Feed - Box Coating
Box Coating
vectrasoundz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vectrasoundz Quote  Post ReplyReply Direct Link To This Post Topic: Box Coating
    Posted: 16 November 2013 at 7:56pm
Hi guys, I was wondering what do you all use to paint your cabs? Every time I search I get an error :( The cabs are mobile so they will get a little abuse. U'm over in Barbados so hopefully I can find what you all use here.
Wade
craig582 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig582 Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2013 at 10:05pm
use google to search the forum " (enter what your looking for here) site:forum.speakerplans.com " copy without speach marks, but tuff cab is good, but i see your in barbados? not sure what you can get hold of
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 2:14am
For Europe my suggestions would be Warnex or Tuffcab. For the US Duratex seems to be the brand of choice. I guess importing from the US would be the cheapest option for you if you can't source anything locally.
I have used car underbody coating before, its very durable but it can leave marks when it rubs agains doors/floors when moving the cabs.
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 9:51am
I'm not saying that you have to ignore other suggestions from people, but you have to remember that people only use what they can get or can apply in the appropriate manner,  If you can get 2 pack polyurethane you will be getting the most durable paint that is readily available.
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 11:08am
+1 on 2 pack pu coatings very durable i think a lot of people wont have access to the facility's to use the more exotic coatings so they use water based products though if you have spent time and money on a cab then you should finish it to the same standard look at some of tony a.s.s. finishing Thumbs Up  i appreciate a good finish as that's my day job ( french polishing / spraying ) Smile
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 4:49pm
What 2 pack system would you reccomend Tony?
I have a spray room in my joinery shop so not limited finish types.
biotec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote biotec Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 7:21pm
proper solvent based 2 part polyurethane glues are the hardest coatings available, I wouldn't bother with water based polyurethane coatings (unless you're looking for varnishes) but some epoxy paints can be fairly durable.
You may find that local car and truck paint suppliers will stock the 2k PU paints. Otherwise you might look at industrial paint suppliers for the paints they use to paint warehouse floors.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 9:39pm
there are only two choices used in the speaker industry
Warnex and Polyureea
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2013 at 11:54pm
Only something that is recognised as 2 pack poly. that's all there is.  As a guitar builder I also use Polyester, which, of course, you could spray onto your cabs, but it is unnecessary as long as you use 2 pack poly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vectrasoundz Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2013 at 11:08am
been searching all round here for two pack poly but have found ANYTHNG Cry tried the underbody coating, it look good but leaves marks as was said *sigh*
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2013 at 11:14am
I guess Barbados might me more tricky than looking at places in the States where a lot of Body shops would use 2k. Still it's not all bad, you are in Barbados after all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vectrasoundz Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2013 at 11:19am
Trying to find out if any one here sell truck bed liner, I think that should work.
Edited by vectrasoundz - 25 November 2013 at 11:20am
