Moving Heads |
Post Reply | Page <123> |
mk2_ginger_biscuit69
profile moving head - discharge is what you are after.
a spot would be like a sharpy beamer etc, not often with gobos just colour and shutter. Important thing is budget really. Id still go with new units under warranty, put them in a fitted flightcase from day1... look after them and they will look after you. on a side note, those Kam powerbars are really quite pathetic, hope you aren't trying to light entire bands with them - fair if just for DJ's. If you are on band work too, id invest your money is decent stage wash stuff + some backlights - ie: strong profile LED cans pointing crowd direction. Id be rather insulted if someone rocked up with 575w discharge heads with those bars to light the stage - don't forget a good hazer/smoker or your beams won't have much effect. |
Biggus
Young Croc Joined: 02 May 2010 Location: Market Harborou Status: Offline Points: 1284 |
Got the Jem ZR33 on smoke, I've been really pleased with the powerbars atucually
trucru
Registered User Joined: 15 January 2012 Location: Cornwall Status: Offline Points: 140 |
We use iMove 250s heads....they are not as good as your Macs, but the price is not the same either. We have had them for about 6 years and they are still going strong, only issues I have had are from one of them being dropped.
250w discharge lamp, removable gobos, motorised focus, can be run in 8 or 16 channel. When we bought them they were about £700 per head new. |
kedwardsleisure
One of my lighting clients is a big-name hire company and they let a rep persuade them to substitue their mac250's for a well-known chinese-made american disco brand. They were told they're piss all over the martins for a fifth of the price.
Several in-warranty pcb replacements later and they turned up on my bench to see why they were failing...the switch mode ballasts were going bang. The uk rep of the european branch of the american importer of the chinese fixtures wouldn't even return my calls until I told them who the end customer was...and even then they admitted that the OEM schematics didn't exist outside of china. Imagine Martin or Robe telling someone that? Edited by kedwardsleisure - 28 July 2014 at 9:35pm |
North Staffordshire |
mini-mad
and thats one reason i like my iMoves
yeah, but a large rental house should know better than to use cheap!! If you are using kit regularly on road/install then like audio - you need to invest in quality. If you aren't a ''heavy user'' then the money often will gain you little...
in fairness to the OP, they haven't really said budget, use [apart from medium venues], whats on stage, frequency of use etc etc.... |
Biggus
Useage won't be to heavy, i.e won't be used everynight all night. Just maybe a few times a month. However I don't want to buy something that will fall to bits in one night.
jacethebase
Have you thought about power? You say you want bright but a 575 lamp is starting to draw some juice. Why not just buy a 250 with decent optics.
www.stage2sound.com |
Biggus
I've not got that far yet Jace, I've only just started doing my research so I'm looking for recommendations of what brands etc I should be looking at. I really hope LED was going to be there but nothing seems bright enough at the moment.
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
The Martin Rush range have a pretty decent output for 'budget' LED, and their budget sharpie is pretty tidy for a third of the price too - however I'd say they were more of in install / light hire thing - are they likely to take a battering? If yes, maybe something older but beefier is the way.
You will spend a bit of time with them on the bench, but at least most things are fixable... |
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Online Points: 1833 |
My bread and butter work over the last few years has been faultfinding public lighting installations for a london council. Ive pretty much come to consider switch mode ballasts as another consumable whereas usually if a wirewound ballast had failed ,more often than not, the fitting would be old enough to replace anyway. Given the failure rate, Im of the opinion that the purported environmental benefits of hf ballasts are a big fat hairy lie |
LOUDER THAN LOUD
Biggus
Oh I'm still undecided..
1) Budget New 2) Secondhand Pro brand
