PD186's over excursion and hot of Proline 3000 |
Post Reply | Page <123> |
tcourtneyvincent
Young Croc Joined: 04 January 2011 Location: Devon Status: Offline Points: 1146 |
Ok great thanks, that makes sense. Seems like i need to just be less timid. I dont understand your last paragraph though. If the peak the amp can provide is 1k per bin, then how can a driver that "supposedly" rated at 2.8k peak exceed it mechanical limit with only 1k especial only being fed 75hz and up...
tcourtneyvincent
Ok thanks, i see why people generally try to go for new drivers or recones!
Andy Kos
Old Croc Joined: 15 May 2007 Location: Southampton Status: Offline Points: 3038 |
Power is very complicated, a driver's power rating is determined by following a specific procedure, with a certain bandwidth of signal, in certain circumstances.
AES rating has a certain crest factor, and it only has to handle the power rating for 2 hours. Thing is, in real life, you dont play music that has the same bandwidth limited pink noise with a specific crest factor in a 650 litre enclosure, and not many gigs last only 2 hours. The heat builds up over time, so a 5-6 hour gig... So the published power ratings are a guideline, and arent 'real-life' they just help determine roughly how big a power amp you can put on it.
Edited by Andy Kos - 26 November 2014 at 11:15pm |
tcourtneyvincent
Yep all limited
Andy Kos
I had a set of second hand Nexo PS15s, about 4-5 years old when I got them, and I used them for about another 4-5 years, always limited using the TD Controller and sensible power. At the end of that time I came to sell them, one of the PS15s had just started to fail with a very slight rub detetcable. The voice coil enamel had simply over time just deteriorated - the coil former was not burnt or distorted, it was purely that the driver had been driven to just within its limits on a regular basis for a long time, slowly but surely destroying the coil. Most of the time, a second hand driver thats been used sensibly will be absolutely fine. I think you have just been a bit unlucky. One thing about buying new, at least you know that if you destroy it, it's definitely your fault, and not the fault of the person who owned it before you! Edited by Andy Kos - 27 November 2014 at 10:05am |
tcourtneyvincent
Ok i understand that you cannot just go by facts and figures, its very easy to slip into going by what pieces of paper you read. I guess i under estimated the power this amp is delivering and the temp in which drivers can get to. thanks for your help
ArthurG
Young Croc Joined: 03 May 2004 Location: France - China Status: Offline Points: 976 |
Andy is right. For the enamel thing (also called insulation layer), their grade varies a lot. Crappy 105C (C = degrees Celsius) is used in consumer products like sound stations. HiFi stuff is usually 150C (degrees Celsius). Chinese pro grade is usually TIL based that can handle 180C. Then the good stuff used no by most Western Pro audio manufacturers in their standard range is Polyimide style that can handle 200-220C, depending on the formulation. Finally the mighty grade is IEC that I use on all my products and this one goes up to 250C. Obviously, knowing that copper can work continuously at 350C, glues up to 400C and fiberglass formers up to 600C, enamel is always the first to burn , so their choice is crucial on the power rating figures. When everything else is equal (especially cooling), going from 180C grade enamel to 250C increases your power handling by more than 40% !!!
Andy Kos
Interesting information there about the different enamels - I see a lot of burnt out drivers with the coil formers also burning and bubbling up, but you are suggesting up to 600C for the former? Are there different types of fibreglass former also?
Earplug
DC on your amp output is not good. Have you checked how much 'a small amount' actually is? And depending on the kind of problem the amp may have, the DC could also vary/increase when being used. Simple to take a multimeter and check that. Any DC will cause a displacement on the speaker and so reduce it´s effective Xlim. That will definitely lead to a shorter life.
Edited by Earplug - 27 November 2014 at 9:36am |
ArthurG
absolutely, they are also many grade of fiberglass, from 300C to 600C temperature resistant. T600, the best grade can be bought from US and Japan. Same for the glues, the ones suitable for voice coils go from 150C to 400C grade. 10 years ago, you could not get better adhesives than 300C. Technology evolves quickly...
odc04r
What you have to remember is the amount a driver moves in a cabinet at a given frequency depends on how much it is loaded at that frequency. I.e. how much the air contained in the cabinet is acting as a spring pushing it back towards it's rest position. If you design a reflex with a port tuning frequency of 40Hz, under that frequency the driver becomes unloaded. I.e. as you go under the port frequency then it behaves less like a resonating port and more like a giant air leak. In this case 1W at 20Hz is going to cause more excursion than 1W at 100Hz. But it is the same amount of power (or amplifier voltage swing into a constant load). So this is why stating that a driver can take 1kW free air relates to only what the voicecoil can take thermally and is nothing more than a rule of thumb when it comes to puttign it in a box. The box changes the game completely. Stating 1kW is also not much help. What you really need to make any useful measurements is a frequency analysis of your source material power. Then you can start making more useful statements about how much power a given box/driver combo can take. As always the real world is a lot more complex than the numbers marketing people like to put on things. |
lost eden
Young Croc Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
If I've put the numbers into hornresp correctly there's an excursion peak at just over 100Hz, in addition to the one at around 60Hz, so there is still a chance of over excursion when playing 75 to 180Hz?
