Turbosound TFL-760H still worthy? |
Post Reply | Page <1234 11> |
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
For what it's worth you can build your own Turbo TSW718 from plans at Marc O. French site, I am looking for Floods here in the US but prices have gone down so much it's worth every penny to invest in.
BASS, how low can you go!
Lincoln1
Registered User Joined: 16 February 2009 Status: Offline Points: 251 |
Not as good as Partya, but hey... Cheap as chips really. Noone here must know what these are:).One hf driver is toast. They gave me a bit of cash-back. I have only ohm'ed them all, and one lf driver may be a bit lower than normal, but all drivers look original. Cabs have had a hard-life with grilles all pushed in and many coats of horrible black paint, and shit spilt down them. The guts is all there so I'm happy. Will be happier when I get time to fire them up. I figured if I can get 6 good ones out of the 8 I'd be doing well, and would be a bigger setup than I'm ever going to need (want is another matter..) First thing is strip and clean all the drivers the best I can, incl the RTD sweet crap off them.
Dutchman
Registered User Joined: 23 March 2013 Location: GENT Status: Offline Points: 365 |
Sand thr cabs down and paint with tuff cab turbo blue from Blue Aran
We need more SPL!
bitSmasher
Or DuraTex turbo blue which is available from Cannon Sound in Australia
Dutchman
That would be more cost effective for you guys. Very cool that those turbo's popped up in new zealand. Dont think they are widely available over there?
We need more SPL!
Lincoln1
No there's only 2 clubs in Auck using F1 that I am aware of. None where I'm from. Around here that is of serious quality seems to be Martin, which the guy that mainly does our outdoor stuff sounds awesome. I forget the name of their horn subs but they definitely put out and just make me smile.
Anyway yeah rocking the Turbos will be awesome. They will look very cool whatever I do, I promise. They will be turbo blue and black f-glass horns. I will attach one of my bp6 subs that made its way to the cave in my shed. Made those 4 back in the early 90's,incl my first Technics sounds from the late 80's..class AA lol. Thanks again so much for the feedback, and looking forward to the rebuild.
Dutchman
Martin WSX? Ok nice keep us updated with some horny pics please! (Double meaning ;) )
We need more SPL!
partya
Registered User Joined: 06 September 2013 Location: New Zealand Status: Offline Points: 105 |
Did you speak to the 'Studio the Venue' staff Lincoln? Apparently the reason they sold the Turbo stuff is because Martin kitted the venue out for free, on the basis they could use it as a showroom. There looked to be some H3+'s and a few WSX's. Not a bad deal! I think capacity is 1100 at that venue, so it would have been a fairly decent install.....
fatfreddiescat
Young Croc Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1082 |
First of al,l well done on your find
RE xover to bass cabs, Brit Row in the UK used to run these with the 21" bass cabs, xover at 150Hz, which was on the low side, but standard practice there as it was the same xovers as used with the Flashlight rig. Take a good look at the gap between the driver cone surrounds and the horn throat, every time these cabs are tilted back and forth the crap gets sieved through the grill and ends up in this gap. I have to agree with what others have already said that to really appreciate these cabs, try as best you can to set it up as an all active system If you haven't already then take a look at this thread, Flashlight used the same drivers: http://forum.speakerplans.com/turbosound-restoration_topic89695_page1.html Floodlights are still one of my all time favs, never tried them with some Martin 115's (y bins) or 215's but I bet they would be killer
yep. i'm working on boxing up 4 floods at the moment. the crossover you can see isn't a crossover... it's a little protection circuit for the 1" driver. absolutely best to run these 3 way. little more investment in processing and amps and nl8 cabling but once it's done it's done and you're up and running then.
popular cab on here these days! that's a big pile of them you have! |
jacethebase
Don't do that! Use a paint that is going to stay on the boxes. |
www.stage2sound.com |
Hvedstrup
Registered User Joined: 30 October 2009 Status: Offline Points: 413 |
I'll give you some facts just to clear up any misunderstandings.
All processor setting can be found here: With TSW-718 the x-over is 180 hz. With TSW-721 it's 150. Don't ever let them play lover than this. The "filter" you see in the boxes isn't a crossover. It's a protection curcuit that transforms the 8 ohm CD-103 1" into 16 ohm and sets the gain. Unless you plan to replace the 1" don't tamper with the filters. You can get original passive filters but they aren't likely to be fitted in your boxes. The CD-103 is really a EV-DH3. The magic of the box is the 6,5" so make shure they are ind good condition. A conversion from EP6 to NL8 is a simple task and only involves i little cable stripping and some soldering. To splay them correctly let the backs touch and seperate the fronts a little more than a "fist" wide. Get your limiter and gain settings correct, drivers are VERY expensive to recone and replace. Enjoy that you own some of the finest boxes ever made. In my ears they put almost everything to shame, including most of the "newer" F1 stuff. Edited by Hvedstrup - 18 December 2014 at 11:41am |
