MY PROJECTS :-) |
Post Reply | Page <12345 10> |
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
man i do need to get autocad
fostonshfs.webs.com |
kr1sounds
i can hear the cries "not another one" but this is priority for me |
kr1sounds
A new system i'm hoping to have ready designed by the end of May
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
Any thoughts on me using a pair of kr1 10" horn using new in the box PD 102 ER which I had for 10 years now I can build a nice phase plug and use this to 400-1700Hz ? Thanks!
BASS, how low can you go!
kr1sounds
go ahead
JTH
Registered User Joined: 10 May 2011 Location: Midlands Status: Offline Points: 42 |
I've been thinking along the lines of something like this for a while, a kind of 10" version of the MT121 and have finished building a rough prototype tonight. Compact horn loaded cab with a 10" mid driver with 2" compression driver. I was hoping to post some pictures but the upoloader link doesn't seem to be working. Anyway, we'll have a listen tomorrow and if it sounds promising, get some measurements done later this week! |
T-Bone
JTH what woofer are you using? I plan to put in my Faital 10PR300's, I have two to test brand new. Also the BMS 2" coaxials would sound nice.
JTH
T-Bone,
We have a couple of drivers to try. The Kappa 10 Pro and Precision Devices PD.10MH25 although I like the look of the Faital 10PR300 you have there and might order one tomorrow. As for the 2", I have a couple of P-Audio PreNeo 750Ns here with a P-Audio PH2723 Horn, but am looking for best mix and match really. I have no experience with the BMS comps, so any suggestions are welcome! Tim |
JTH Concerts & Live Events - Stage Hire, PA Hire
JTH
Here we are then, rough prototype of our 10 + 2 hornloaded cab. Hope to get measurements later this week :-)
Edited by JTH - 29 April 2015 at 4:56pm |
T-Bone
Nice work JTH, I am still drawing this full size a only have a few hours per day to work on this since I work 12 hour days and only an hour or two when I get a chance. Are you planning on putting a phase plug? Waiting on the results JTH, thanks!
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1508 |
JTH I do like the look of you cab.
A BMS 4590 would work well, on a big horn could drop it too 850Hz or so |
kr1sounds
did you use my design or your own?
