MC2 vs QSC Powerlight |
Stray-Sounds
Old Croc Joined: 13 March 2008 Location: Wales Status: Offline Points: 2426 |
Posted: 01 May 2015 at 6:19pm |
We've bought a logic system VA rig and need amps. Our options are MC2 E45s or QSC Powerlight equivalent.
Could people share their opinions on these amps? The QSC are much cheaper, are they as good at the mc2? Many thanks :) |
<a href="http://www.soundhirewales.co.uk/">PA & Lighting - Sound Hire Wales</a> |
csg
PL3 series?
If so, they are very good amps.
Stray-Sounds
Yes, pl380.
Don't spose you know how they compare to an E45? |
csg
both are great bits of kit, i would probably go with the 380, particularly if it is cheaper.
Stray-Sounds
Thanks. I think we'll have to find a way to try both!
Liteworks
Registered User Joined: 29 April 2008 Location: Cambs / Luton Status: Offline Points: 383 |
PL380's are good solid amps, very similar power wise to E45's so a good alternative.
Not heard the E45's in direct comparison so can't comment on any differences (or not), but happy with our PL380's (we use for everything from Mid & Low in 3way tops, full range monitors and Sub's). -m |
bmw28
Registered User Joined: 28 December 2006 Location: West London Status: Offline Points: 233 |
Is there is any major difference other than power between PL2 & PL3 series ... using PL 236 on hi/mids at the moment...
csg
for me, not enough to make a change if you have enough headroom on the 236.
Liteworks
Not much if any difference really, they've both the same (or very similar) I/O options on the back of the amp's. The PL325 and PL340 are similar design and power output to the the PL2 range. The only major difference is the PL380's are a different design and a lot higher power point than any of the PL2's. -m |
Stray-Sounds
Okay thanks. Another thought.. How does the MC2 E100 compare to a Lab FP10000q ?? I'm aware of power rantings differences on paper but wondering how they compare in real life?
Thanks |
londonavc
Registered User Joined: 01 April 2012 Status: Offline Points: 148 |
I have used both, especially the PL380s, used MC2 E45,90,100.
I would personally go with the QSC's. It would be interesting to do a direct comparison. The QSCs will save you a lot of money too... Typically now a PL380 is around £2500. Whereas a MC2 E90 £3500. Both come with 5 year warranty I'm sure, MC2 is UK based. Excellent cs. |
4AC
Young Croc Joined: 18 September 2010 Location: Netherlands Status: Offline Points: 521 |
Why? Have you compared both sonically?
Or £715 used (ex shipping to UK): http://soundsale.nl/occasions/product/1151/pl380 Ridiculously cheap. |
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
