18TBX100 in Gsub |
Rudeboy94
Registered User Joined: 25 June 2015 Location: Firenze, Italia Status: Offline Points: 102 |
Posted: 12 February 2016 at 5:25pm |
I have opportunity to buy an empty Gsub cab for a low price and I already got 2x these big boys. What I'd like to do is to use these two B&Cs to reproduce the kick bass 90-180Hz (I've already stick the other two in scoops for subwoofer) is it a suitable combo?
Followin' the vibes
ceharden
Yes the 18TBX100 will work fine in the GSub for general purpose bass (e.g. 40-120Hz) but I don't think using that combo for 90-180 is a good plan.
king david
it will work but wont be the best
Rudeboy94
It's my first reggae rig so I thing that I'll use it, because of the low low cost of this solution, I'll put it in the list of things to change as soon as possible
Followin' the vibes
ceharden
The drivers are good but you'd be better off aiming to have either all 4 in GSubs or all 4 in scoops, then something more suited to the kick region.
king david
follow that advice, you may get away like that for beginning, and when you expand the rig, you can put the 4 tbx in scoops
Rudeboy94
yes when I'll upgrade that will be the rig! This is just a midway solution, then I'll put some other speakers in the Gsub
Followin' the vibes
Rudeboy94
However, shall I cover some internal parts of the Gsub with foam? Now is naked wood
Followin' the vibes
Explicit 2
Registered User Joined: 02 May 2016 Location: Staffordshire Status: Offline Points: 91 |
How much does used G Subs (18") go for, unloaded and loaded?
Thanks
