  New Posts New Posts RSS Feed - RCF LF15X401 In Scoops
Ruggeddave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ruggeddave Quote  Post ReplyReply Direct Link To This Post Topic: RCF LF15X401 In Scoops
    Posted: 17 March 2016 at 8:43am
Aye up,
Got a 15" scoop, wanting to know if the RCF driver will work in it.
The box was 'designed' around the OBERTON XB700 and thus has a chamber size of 30L (with driver in).
The throat area is 481cm^2.
I've changed my mind a little (as the RCF will give me 3db more output before XMAX, according to my sim), can I get away with putting the RCF LF15X401 in there? My main concern is the VAS is 140, and thus the chamber size of the box will be too small.
I'm sure someone will be along to tell me the only way to find out is to try one, but I want to know if I'm way out here or it might work.
I'm aware Jah chalice soundsystem use this driver in their scoops, They are a lot bigger than mine mind.
T/s parameters of the RCF:
  • Resonance frequency: 34 Hz
  • DC resistance: 5.5 O
  • Mechanical factor: 7.6
  • Electrical factor: 0.30
  • Total factor: 0.29
  • BL Factor: 26.5 T ยท m
  • Effective Moving Mass: 170 g
  • Equivalent Cas air load: 146 liters
  • Effettive piston area: 0.091 m2
  • Max. linear excursion (mathematical): 11.5 mm
  • Voice coil inductance @ 1kHz: 2.5 mH
  • Half-space efficiency: 1.90%
    Cheers
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2016 at 5:46pm
Good driver for scoop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2017 at 9:18pm
Intersting, just about to build a scoop for testing for this driver
DJ123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ123 Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 6:24pm
what about the RCF LF18N451 will that work good in a super scoop cabinet ? thank you
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 6:33pm
I really don't rate 15" Scoops.
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 8:10pm
Yeah, agreed. two of the most disappointing things for modern EDM :  JBL 4520 and W Bins. They need sub, plenty systems found this out quick in the early 90's and that wasn't really sub as it is now.  However, if the 15's scoops are to play older music then could be a nice retro option?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2017 at 9:00pm
You can buy 4x Used unloaded 18" SteveB scoops, drop in 4x used PD1850s, spend £700 on used 5K heavy, or big SAE, and have enough sub for 500 people.
Using 15" Scoops, dunno, dunno, dunno.
This page was generated in 0.047 seconds.
