FANE loudspeaker enclosure design and construction |
Post Reply | Page 123> |
space141
Registered User Joined: 18 June 2015 Status: Offline Points: 30 |
Posted: 26 March 2016 at 4:19pm |
Hello,
Does anyone happen to have a copy of the FANE loudspeaker enclosure design and construction book lurking around on their hard-drive somewhere? Apparently used to be available on this website OzValveAmps but seems like the link isn't working anymore (perhaps they are no longer in business.) Cheers in advance, Thomas.
csg
space141
Thank you every so much for uploading that - nice to have an scan from the original manual. Do you know where I might be able to get a copy as I spent a considerable amount of time yesterday looking for something online but didn't have much luck.
Thanks again, Thomas.
APW
You have mail
Biggus
Young Croc Joined: 02 May 2010 Location: Market Harborou Status: Offline Points: 1284 |
Did you get a copy? I've got a copy in PDF format if that helps
freelanceav
New Member Joined: 17 April 2017 Status: Offline Points: 8 |
Hi guys and gals. My question is somewhat related.
We built some Dual 15" FANE bass bins in the mid 90s, with rather good performance and I do not have the plans anymore. I will attempt to upload a photo ... The designs use the 15XB drivers, although the current version of these drivers have been updated. I am not sure if these plans were in the FANE design book, so my question is two-fold: 1. Would someone kindly send me a copy of the book if they have it in PDF form? 2. Does anyone recognise these designs (I'm referring to the bass bins, bot the mids) If anyone recognises these bass bins and havs the plans, I would be grateful if you fould forward a copy. |
jazomir
Old Croc Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1711 |
Link to larger plans here:ere:
Edited by jazomir - 19 April 2017 at 10:24am |
APW
Freelanceav, I also have the old Eminence book (very similar to the fane book) that has a dual 15" ported W bin, dual 15" Bandpass, a dual 15" scoop and a dual 15" BR cab. You need to get your post count up to 10 so I can PM the PDF to you. TBH, by todays standards these are not the best designes and far better self build cabinet are now avaliable. Alan. Edited by APW - 19 April 2017 at 11:06am |
freelanceav
Thank you, Alan.
No, they were not W bins, but have the most amazing performance for what they are. I'm going to revive this little project and wanted to give the bins a new face-lift as they seem very dated. We measured 132dB @ 38Hz with these at the time in a chamber and they are only FANE Colossus 15XB drivers. Not the highest SPL for these days, but they do have a very tight response. The designs were 'unofficially' given to me from a FANE contact around 20 years ago, who is no longer with the company. I'm trying to avoid going down the route of reverse-engineering the designs. I had a look in the FANE design book and these designs are not in there. The smaller 2-way cabinets in my photo will also be re-configured to be bi-amplified. I have never been a fan of passive crossovers. I'm also fitting new fly gear and replacing all the hardware with better quality and more aesthetically pleasing items on all the units. I would be interested in seeing the Eminence designs if possible, please? Regards, William.
Edited by freelanceav - 19 April 2017 at 11:32am |
Biggus
They remind me of a bigger version of the Tannoy T40 - however looking closely there not.
I've not seen this design in the fane book - here are the links to the book in PDF format (found online and working for me) Edited by Biggus - 19 April 2017 at 11:47am |
freelanceav
Thank you, Biggus.
I also managed to get hold of the FANE book yesterday and agreed, they're not in there. Like I said, I was given the designs 20 years ago by a contact from FANE, who is no longer with them. I will reach out to FANE and see if they are willing to help and/or have knowledge of these designs. Looks like I may potentially have to reverse-engineer them. Regards, William. |
freelanceav
Email sent to FANE UK. Will post an update if I receive anything of use.
