Crown XS1200 Amplifier PIC Controller |
Post Reply | Page <123> |
CaptenMorgan
New Member Joined: 28 December 2016 Location: Limnos Status: Offline Points: 6 |
hi guys
I have 2 crown amps xs900 and xs1200 for repear . on xs900 the pic 16c57 is damaged. I need the hex to program a new pic .Is the same hex with above Pulse 2x1100? .can I use it? |
TMH Music
Young Croc Joined: 07 April 2011 Location: London Status: Offline Points: 637 |
Sorry to hijack this thread, but as the owner of an XS1200, I am curious as to people's opinion on the reliability of this amp. Is this PIC controller problem a known fault? Any advice on how to keep this amp reliable would be gratefully appreciated.
ceharden
Failure of the PIC controller is fairly uncommon. I've only seen one myself on an original Pulse.
Biggest tips for keeping any amp reliable are keep them clean and dry and don't drive them hard into low impedance loads. Although the Pulses/XS Series are rated for 2Ohm operation, I wouldn't. They are best suited for mid-top applications which they sound very good on.
CaptenMorgan
In my case the pic falure cased by 5v supply. A bc546 sorted and pass 30v to pic.
xc900 and xs1200 is exactly the same exept some smaller power supply capasitors. Can i use this Hex? xc1200 and pulse use the same Hex? I mast be sure. thanks
kedwardsleisure
you'll need the firmware version, it'll be printed on the label on the micro.
North Staffordshire |
simonp1100
Young Croc Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1110 |
Hi,
PIC's info marked on them is as follows:-- Crown XS1200 = REV.:1.09 (CS.: 8778). C-Audio Pulse 4 X 300 = (RX5066 V1.06). I think (correct me if i am wrong) but software RX5066V106 is for the 4 channel amps & RX5066V107 is for the 2 channel amps. Hope this info helps. |
jacethebase
I have loads of Pulses and a fair few XS1200's and 700's all mine are fairly reliable and sound great on wedges.
www.stage2sound.com |
CaptenMorgan
both amps xs 1200 xs900 have the same version rev109 cs 8778 .
you think RX5066V107 is ok to me or is only for 2 channel pulse ?
simonp1100
I would use the RX5066V107 software.
CaptenMorgan
ok
thanks to you one amp have a chanse to return fron the land of dead amps
kedwardsleisure
I have V1.09 if you need it
CaptenMorgan
can you send me or give download ling ,please?
