10/12u Foam mount flight case |
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2460 |
Posted: 25 September 2016 at 8:06pm |
Looking for ideally 12u but 10u will do, foam lined flight case. Needs to be deep enough for MC2 MC series so not massively deep. Im located near Watford, I can collect with in reason. Cheers.
DPR2001
Registered User Joined: 27 May 2008 Status: Offline Points: 343 |
Hi,
I have a number of 10u foam suspended flightcases, 500mm depth on centre box, front and back rail and doors: 150 (sf discount) and can meet you in Oxford on a weekend for £20.
deja-ibiza
Young Croc Joined: 09 September 2008 Location: Guildford / Ibz Status: Offline Points: 770 |
I've got a 12u foam lined Flightcase available. It's MC2 depth, on castors, Diamond-board. Located near J10, M25.
Pics and & measurements can follow later today. Edited by deja-ibiza - 26 September 2016 at 2:42pm |
deja-ibiza
Pics of the case I have below. It has front and rear rack strip, as well as an inner rack strip towards the rear (see last pic) Measurements are: 570mm front to rear rack strip 470mm front to rear inner rack strip. 75mm lid depth (Please ignore the patch panel) Edited by deja-ibiza - 26 September 2016 at 5:37pm |
boots-hifi
Thanks, can you pm the price for the 12u please.
jacethebase
I have loads of flashlight 12u steel framed rack cases.
Check eBay they are on there. Will do better prices for SP members. Probably your only chance to get multiple matching cases without buying new. J |
www.stage2sound.com |
midas
Flightcase wearhouse, 12u new with casters 199.00
Studiospares 8u foam, new 129.00. Must have sold 12u but not much more when they are in stock. |
boots-hifi
Cheers, ill have a look! |
jacethebase
Cheep foam ones are normally shite, as they are just lined with cheap foam and eventuallly where the sleeve sits on the foam it will compact it. More expensive foam cases like the looks of the one DJ-Ibiza posted will have rubber pads in the middle of the foam to take the weight of the sleeve when upright. J |
supremesoundz
Old Croc Joined: 26 January 2009 Location: London Status: Offline Points: 2689 |
supremesoundz
18u £120
10u £100 Cases by AOS London in diamond board finish Based in the Uxbridge area. Although the 18u case is in Heston (you've been there before Ben) |
boots-hifi
Pm'd. You love those FBT's !
