  New Posts New Posts RSS Feed - Dual 18 HBPH
Dual 18 HBPH
suiluj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Topic: Dual 18 HBPH
    Posted: 30 September 2016 at 5:37pm
Hello guys,
What would be other softwares to possibly simulate this hybridbandpasshorn?
Still working on AJhorn but still can't get it right.
Cheers!
BooM BASSTIK EleCtronics and Communications Engineer
Live in harmony with one another. Do not be proud, but be willing to associate with people of low position. Do not be conceited.
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2016 at 5:53pm
AKABAK
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2016 at 6:00pm
Cheers,Smile I will work on it especially on the 32bit emulator, I am currently running on a 64bit windows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2016 at 6:24pm
Look forward to seeing the results of the stubs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2016 at 2:06am
Will post new updates after finishing the prototype, start cutting woods next week.
Edited by suiluj - 01 October 2016 at 2:35am
Post Options Post Options   Thanks (1) Thanks(1)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2016 at 10:24am
For the stubs I would think in terms of mass and compliance as regards to the chamber and ports, there will be a resistance component, more so if the ports are made up of lots of small holes instead of three or four larger holes.'Hornresponse' by David McBean would model all but the stub, much simpler to use for initial design and the output can be imported into AKABAK.
bitSmasher View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2016 at 1:29pm
Could you use the stuffing/damping function in Hornresp to emulate the resonator?
Might be worth starting a thread in DIYAudio sub forum, some seriously good sim geeks on there (including McBean)
Post Options Post Options   Thanks (0) Thanks(0)   Quote suiluj Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2016 at 2:51pm
Thanks guys...Smile been spending few hours on this AJhorn at the moment.
I will try to look further on the hornresp.
Also I have check the DIY audio sub forum, guess you are right bitSmasher, a lot of geeks there with good discussions to ponder and learn including stub/cone compensation.
