  New Posts New Posts RSS Feed - Drivers and their enclosures
George1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George1234 Quote  Post ReplyReply Direct Link To This Post Topic: Drivers and their enclosures
    Posted: 16 January 2017 at 5:15pm
If I have a 6" sub how do I work out the size and type of enclosure to build for it? I aim to build a mini system for my room,
If anyone can help, would be greatly appreciated!
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2017 at 5:16pm
By the individual driver parameters
Post Options Post Options   Thanks (0) Thanks(0)   Quote George1234 Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2017 at 5:18pm
I'm new to understanding drivers - which parameters would I need to be looking at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote George1234 Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2017 at 5:22pm
What sort of parameters should I be looking at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2017 at 7:08pm
all of them t/s prams of drivers/spec ect
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2017 at 10:18pm
You've got a lot to learn! Start here - http://speakerplans.com/index.php?id=faq1
What is the make/model of the driver you have already?
Post Options Post Options   Thanks (0) Thanks(0)   Quote George1234 Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2017 at 10:30pm
I have none yet, im just thinking of building a small system - is there a way of building a horn loaded cabinet to fit a 6/9" sub?
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2017 at 7:51am
the problem with horns is that for it to run bass frequencies it needs a long enough horn and a big enough mouth, so unless you want to use a stack of like 12/16 horns then there is no point.  and i dont particularly think you want 12+ cabs in your bedroom? [actualy if i had a big enough bedroom,..... actualy no id still rather just have 4 18s tbh but i still wouldnt use that in my room] theres a 6" tapped horn tham6 i think its called might do what you want, might be better just to have a sensible reflex cab tho... horns are realy designed for a specific job, using them outside of that is like trying to do the paris dakar rally in a formula one car
horn loaded for her pleasure
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2017 at 8:14am
wont let me edit, but the tapped horn will work as a single unit unlike most horns which need big[ish] stacks
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2017 at 9:18am
the result of a micro scoop for a micro driver is strictly for fashion and looking pourpose,
 i tried a couple of 5" speakers for a friend... they cant go down in no way... but the result is not so bad...
theory some times can be forget and choose by your hears.
 my suggestion is to forget about how accurate is the scoop enclosure and find a decent driver as suggested by others looking to the ts params... keep in mind that so little transducer can't be compared to the standard big boys
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2017 at 9:36am
Your only hope for a 6" driver and low frequencies is a bandpass or reflex assisted enclosure unfortunately. And it won't be any old 6" driver for decent results. The bandpass might give you some rumble but not much else. Your best bet with a 6" driver is to build a pair of floorstander or bookshelf speakers. Might be a bit more HiFi looking than PA but that's the world that 6" drivers come from generally.
Generally due to the way 6" drivers are made for PA you are going to struggle to get anything lower then 60Hz out of them and the power you cab give will be limited. As long as you realise that then build anything for practice and looks. It's all good woodwork practice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote George1234 Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2017 at 2:58pm
Thanks very much! So I should start looking at small systems, like a Hifi system to get started with? Is it possible to use 12" drivers or higher? Or does it all depend on the t/s parameters?
