15" mids enclosure |
Post Reply | Page <12 |
RkH
Registered User Joined: 06 September 2016 Status: Offline Points: 21 |
Thank you for your response. We have 2 4-way analog crossovers, te amps are very old and there is not information about them "PROMASTER", but they work good, we've tested with old boxes and the drivers we're talking and sound really good. Total 2ampsx1200w+2x600w+1x300w at 8 ohm. total. |
bob4
This would be another point in favor of three-way, you could run it with your present amplification :) If you want to use your analog crossovers for the system it would be preferable to have direct radiating (reflex or closed box) instead of various horns of different length. To clarify: 1. what model are your analog crossovers? 2.you already have the hi freq drivers+ horns? 3. you have 4 x beyma 15", but no enclosure yet? 4. 18" subs not built yet? 5. You want to make mono stack or also have the option to do stereo? Edited by bob4 - 20 February 2017 at 7:49pm |
RkH
Yes, in a time we will get the DSP so we can add delays and do a better control on phases. Finally we decided to go without the 15", and now: 1. They're the samson, as i said we will get a DSP in a time so we can control better de crossover freq. and add delays. Is it good idea to add a analog cross after de dsp? so we can do a total bypass faster than on the digital one.
2. Yes, look the other post. I sent a detail image from the 3D. 3. No, we had 2 full range boxes and inside them, only one is beyma, the others are not labeled so i think they're no beyma. 4. No, we we'll do a scoop with the current drivers and we will add the 1850 in a time. 5. I have an option for stereo, each cross is 4 way mono or 3 stereo, i can do a sound chain and go out with 5 stereo (mixing them) or 4 stereo (using them as mono). What configuration should fit better? And now my opinion, the samson analog have delay control in the first band, in son in 4 ways mono only i can affect the subs, but if i atack the input of the second with the output of the first highs, i can control delays on mids. Do you think this is tricky or just useless? The question is 4 or 5 ways? I never said i was gonna use 3, i have more amps and crossovers outputs and the needed equipment. Edited by RkH - 22 February 2017 at 12:00pm |
