  New Posts New Posts RSS Feed - 8" sub cabinet
8" sub cabinet
Padde298 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Topic: 8" sub cabinet
    Posted: 21 February 2017 at 2:39pm
Hi Guys.
I am working on a "SONOS-Killer" project, and have come to the subwoofer part of the project. I have 2 pcs 8 inch units for the job. Is there any chance there is a plan for a compact enclosure, ported, bandpass or the like that will fit my project?
All suggestions are welcome! Clap
Just remember that the "wife factor"Cry is in play, so "the smaller the better"!
(I know it poses dificulties getting bass from a small cabinet, but isn't the life all about finding solutions?)Wink
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2017 at 6:02pm
without knowing your particular drivers TSP no one could recommend anything..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2017 at 8:48pm
They are Vifa M22WR-19-04, 4 ohms, long stroke units. I have the pdf data sheet, but don't see how to attach it to this post...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2017 at 8:54pm
Vas 20 ltr
Qms 3,44
Qes 0,87
Qts 0,70
Eff cone area 224 cm2
VC induc. 0,9 mH
Free air res 48 Hz
VC resis 3,2 ohms
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 7:43am
Updating the post with T/S data...
Edited by Padde298 - 22 February 2017 at 7:59am
LOUDER!!! MO BASS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 7:47am
LOUDER!!! MO BASS
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 9:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 9:54am
Thanks for the reply, but the link is bad...
LOUDER!!! MO BASS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 9:55am
Oh, got it... Had to delete the "%20"...
That's a lot of text...Cry Was hoping for a more specific concrete suggestion for an enclosure
LOUDER!!! MO BASS
cravings View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 10:06am
http://www.speakerplans.com/index.php?id=faq1
it opened badly for me too.. but it's the first FAQ there.. easy to get to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 10:29am
Watch out for drivers with really high Qts values of 0.6 or above, these would require such a big box to work correctly that in normal size boxes you don�t get much low end. They are better of being used on the rear parcel shelf of your car, where they can enjoy a massive rear chamber
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2017 at 10:30am
Hi padde.
I'm a novice here too so here's what I had to learn:
Either there is a plan for that driver, or you can build your own or mod an existing plan to suit.
If you want to build a cabinet specific to that driver the best thing to do is download a programme called winISD.
Google how to input the ts parameters.
Open two or three projects in winISD and mess about with the box size and tuning frequency until you get an idea what looks good.
Then come back and once people see you're serious they'll help you make sure your cone excursion and vent mach are ok.
