  New Posts New Posts RSS Feed - I am making a 6U Rack fan
razorray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorray Quote  Post ReplyReply Direct Link To This Post Topic: I am making a 6U Rack fan
    Posted: 02 March 2017 at 9:47am
Have a few days of work and got bored so decided to make a few 6U rack fan units for my 12U amp rack.
I had most of the spares already so got a 2.5mm aluminium sheet cut to size with the correct sized holes and ordered a few bits.
I know its overkill but I like lights, meters and large fans..
Got the aluminium cut and drilled a few extra holes and etch primed it, Will update as I progress
Going to spray it in black today. Will add a picture of all my spares.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorray Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 12:09pm
The small LCD panel meter is for temperature and humidity
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 12:37pm
Interesting. Following....
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorray Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 2:00pm
Etched primed and sprayed it black. Will clear laquer it later on today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorray Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 9:46pm
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2017 at 10:14pm
Tidy
Finjby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Finjby Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2017 at 11:28am
Are you fixing these into the racks via the rear rack-strip?
I did some work for a rental firm who used something similar, their Version2 had a hinge and Southco catch for quick and easy access for re-patching.
Nice work BTW, loving the LCD!  It would be nice to see a wiring diagram if your willing to share?
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorray Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2017 at 1:04pm
The fan unit will be fixed in place on the rear of the rack on the rack strip with 2 x 3U vents to make up the 12U. No hinge.
The audio patch panel will be on the front of the rack permanently fixed.
No wiring diagram. The 4 fans are daisy chained together and go to the IEC socket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorray Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2017 at 11:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2017 at 12:12pm
I may be missing something here, but why the IEC pointing outwards?
Isn't there a power source already in the rack to run amps / DSP? Which is fed from the front patch panel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote razorray Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2017 at 1:46pm
Patch panel already made and wired. No space for an IEC. Any way thats the way I want it..
