  New Posts New Posts RSS Feed - Scoop Issue (Plays deep but doesn't hit hard)
 Post Reply Post Reply Page  <12345 6>
MINTEVENTRESOURCES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:00am
[QUOTE=levyte357-] [QUOTE=MINTEVENTRESOURCES]
Hello All / Lev
Below are the requested measurements.
What is depth from Rear baffle to inside of front baffle, in mm? = 231.775mm
What is the width from left to right, inside of chamber, in mm? = 571.5mm
What is the length from top to bottom of rear baffle, in mm? = 406.4mm
Is there just gap at bottom of rear baffle? if so what is height, in mm? = 174.625mm
Mint Event Resources
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:11am
First of all, put some picture here so people can see what is going on.
Second, 18LW1400 is not a bad driver, it is pretty much same thing with the RCF 18P300 that is one of the recommended drivers for the Rog's scoop.
Now it is outdated for sure, but for a moderate spl job it should do just fine.
Pictures
Edited by MINTEVENTRESOURCES - 16 April 2017 at 3:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 11:18am
Hmmm, i dont see anything wrong with the box.
Maybe its the scoop sound that you are not use to.
As you can see almost everyone are using them with a kick box above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 1:20pm
I know and love the scoop sound. I am missing the pressure the kind that makes you want to run from the speaker.
djkeet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:30pm
Originally posted by odc04r odc04r wrote:
Why do you think a driver's free air sensitivity matters once it is mated to a horn? It isn't working into free air anymore.
Well I would have thought this would be a good indicator (Considered along with TS params)of power efficiency but it appears your saying its irrelevant, so it doesn't really matter that I thought that the PD was more sensitive but also its Irrelevant that the Void is, as it has to sit in its own specific design like all subs. As far as I know there's not many people that use Void in scoops.Cheers
Edited by djkeet - 16 April 2017 at 4:26pm
Soundbite
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:48pm
Sensitivity is always averaged from the pass band way out of operational range. In most of the cases 100-500hz.
For subwoofers you need to look at other things.
QTS, VAS, BL X-max.
Heavier cone drivers will have more x-max and thus shift more air.
Will need more power, but that is not relevant because we are after the max spl, not the 1w spl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 3:49pm
The size of that throat is enormous man, and a strange up angle panel, imho
so its probably down to the design
i aware of the top heavyweight scoops buildwith large-ish throats
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 4:14pm
No solution Dub? Or suggestion of such? Patiently awaiting Lev's response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 16 April 2017 at 4:46pm
I've got a few scoops/and I'm comparing and thinking the same as you Dub SP the up angle panel sits low it should be more acute this design will play low freq I cannot see how your going to have your cake and eat it. Will there be any consideration to bracing in the horn mouth, is their any reason why horn plans on here or others (established) minis weren't considered first
Edited by djkeet - 16 April 2017 at 5:09pm
Soundbite
