FTH12 Tapped Horn |
Post Reply | Page 123 8> |
Tony Wilkes
Posted: 30 October 2011 at 1:12pm |
Mentioned this a few times but only recently got round to doing any serious testing. Not claiming anything special just a tiny 12" Tapped Horn. Size is 550w x 370h x 455d
Much better performance than with the driver in a ported cab. Output is about 2.5db down on my THAM15's and it looses about 8hz on the bottom end. Driver is the Celestion FTR12-4080HDX Design is inspired by Martinsson's THAM15's which still put an enormous stupid grin on my face. Tony Edited by Tony Wilkes - 30 October 2011 at 2:44pm |
cuivenion
Young Croc Joined: 30 January 2005 Location: United Kingdom Status: Offline Points: 971 |
How does it compare to your BMS double 12's tony?
help!!!!!!!!!!
Tony Wilkes
The double 12's have the extension of the THAM15 and sound good up to 200hz, The tapped has more output and sounds excellent when used 45-150hz, it is silly powerful for its size :)
Tony |
cuivenion
Just wondering why you haven't used one of your BMS 12" drivers for the tapped horn, are they not suited to that type of design.
help!!!!!!!!!!
Tony Wilkes
As you say not suited, for this type of design a highish Fs is a big plus.
Tony |
cuivenion
Looks like a nice design by the way!
help!!!!!!!!!!
login4
Old Croc Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
very cute tony, should be nice and cheap to build too, do you plan to release the plans for peeps?
cheers
CELTIC SUBSONIC SOUND SYSTEMS
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5227 |
Look's like a nice compact cab Tony, Now cue 3 pages of "what other driver's will work in this box"
soundchippy
Young Croc Joined: 09 September 2011 Location: Tavistock Status: Offline Points: 770 |
looks good. smaller than the mth30 and seems to go a little lower with same efficiency (is it 1w measurement?). will you post the plans?
soundchippy
is this small enough to get 2 cabs from 1 sheet?
Tony Wilkes
Yes indeed, as soon as I have tidied up my drawing I will do a PDF. Regarding other drivers, as long as they are pretty close to the T/S parameters they should work. Tony |
Tony Wilkes
No the measurements are not to a reference level. You have to ignore the simulated output level as well, the only way is to build and measure which is the only way I will ever do it. From memory the path is longer than the MTH but I suspect that it will probably not be as efficient as it is a smaller box, there is no such thing as a free lunch. Tony |
